5ek cam questions
Discussion in 'Freightliner Forum' started by insertnamehere, Sep 7, 2014.
  1. insertnamehere
    insertnamehere Light Load Member
    111
    122
    Dec 16, 2013
    Getting head gasket done on 5ek in a 95 freightliner classic I bought. When the head came off we saw that a couple of lobes on the cam looked bad so now need a new cam, upgrade time! Open to suggestions want most bang for the buck. Thanks.
  3. wore out
    wore out Numbered Classic
    17,324
    215,110
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Talk to Hillcrest Cams in Little Rock Ar. They have options, due to forum rules that I'm not sure about but do want to do right by I will let them explain what they have available.
    BeenJammin Thanks this.
  4. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    :biggrin_25513::Ambulance car v2:
    Them gas cans got a warranty?
  5. wore out
    17,324
    215,110
    Jun 5, 2013
    Most likely if you get a reman cam from Riggs CAT it comes from Hillcrest. They have 3 other options depending on what you want.
    The Admiral Thanks this.
  6. insertnamehere
    111
    122
    Dec 16, 2013
    Will call them in the morning, figured why go stock since the motor is already apart. And gas cans are sold as is no warranties.
  7. sailboatjim
    sailboatjim Light Load Member
    292
    173
    Aug 27, 2014
    Boston, Mass
  8. Diesel Dave
    9,654
    32,697
    Jan 20, 2010
    Hesperia, Ca.
    Not recommended on a a 5EK block. 5EK is limited for horsepower due to weaker block. From what I read on forums including here(at one time), on a 5EK block you dont want to go over much 750 I believe. I myself run a 5EK block with modified ECM. To the OP, google what your looking for and you will see other forums that will discuss what your trying to accomplish. You CAN"T discuss mod's on here anymore.....Goodluck
    insertnamehere Thanks this.
