5th wheel disaster averted
Discussion in 'Experienced Truckers' Advice' started by thelinedriver, Apr 21, 2024.
  1. thelinedriver
    thelinedriver Light Load Member
    117
    72
    Dec 24, 2017
    So here's what happened, I've been driving for 15yrs, and I've been driving the same truck for 2yrs, everything was fine,just left company shop 1.5weeks ago, heading to florida,then, te texas, then California, as we are leaving California going up 15 to Barstow for a bite, I pulled into one of those dort lots to turn around and as I'm about to make the turn, going about 2 miles an hour, the trailer disengaged from 5th wheel, needles to say the trailer buried the landing gear, but not too bad, not sure how this happened, before leaving shipper in chino, I double checked everything, it was connected! So then I drive the 80 or so miles to Barstow, up hill all the way with 26k on trailer!! Finally get the truck over to the shop to look at 5th wheel,because I found metal fragments around it upon inspection after it disengaged trailer, shop confirmed metal fragmented up to one inch thick broken off inside 5th wheel!! What!! I never heard of this before what happened? No one has any real answers, my question here is has any one ever even heard of a 5th wheel breaking? I sure haven't and even more so (proof of God), I drive 80 miles up hill with 26k on trailer , why didn't it break then? I'm feeling lucky ,but also thinking of hanging this up, what's your thoughts?
    silverspur and Magoo1968 Thank this.
  3. Dennixx
    Dennixx Road Train Member
    4,549
    14,636
    Feb 13, 2010
    twin cities
    We have had 3 of the low profile Holland greaseless 5th wheels fail and drop trailers.
    One was found to have been assembled incorrectly after a rebuild and the other 2 I haven't heard from management.
    They were sent back to manufacturer for metallurgy testing.
    These were the aluminum plates that used a thin Teflon pad in leui of grease.
    We have since moved away from the lo pro style but continue to use Holland aluminum.
    gentleroger and tscottme Thank this.
  4. thelinedriver
    117
    72
    Dec 24, 2017
    Mine is a Holland as well, the scariest part is what if it had failed while traveling 40mile an hour up hill on 15? There were tons of vehicles behind me, and for the first time in trucking I was scared! For loss of life and for myself and my wife, you know they would of slapped manslaughter charges on me! I'm completely shutdown mentally thinking of what ifs!
  5. Dennixx
    4,549
    14,636
    Feb 13, 2010
    twin cities
    Doubt you would be charged for an equipment failure that was a defect of some sort..
    Like most things there are maintenance requirements on 5th wheels for the owner.
    The manufacturer would likely be liable after the investigation from both parties was finished.
    Scary yes I'm sure.
    2 of our failures happened on the road but only 1 at around 30mph and 1 around 10.
    Both times the rigs had successfully made a prior trip/delivery so there was no way to predict this.
    We leave at 80K every trip.
  6. Dennixx
    4,549
    14,636
    Feb 13, 2010
    twin cities
    USA
    thelinedriver Thanks this.
  7. Diesel Dave
    9,716
    33,175
    Jan 20, 2010
    Hesperia, Ca.
    I use this constantly. Before hooking up every trailer I pull, this is applied;
    silverspur and flood Thank this.
  8. 201
    201 Road Train Member
    12,804
    26,352
    Apr 16, 2014
    high plains colorado
    Are you sure the wagon wasn't "high hooked"? In all my years, I only "dropped" a wagon once. Out of the tens of thousands of times I pulled the pin, and rehooked, it never happened. The only time it did was with my old Pete, it was like 0 out, and the jaws were sticky. Due to the design of the 5th wheel, I believe, when hooked, unless a catastrophic failure, it can't come loose. Pressure from being pulled probably kept it hooked. We have to remember, we can't have 0 risk, and the gremlins in the machine surface from time to time. If it's any consolation, since it happened to you, the odds are it will never happen again. Great catch, driver!
  9. RockinChair
    RockinChair Road Train Member
    5,397
    14,534
    Feb 19, 2012
    Lubbock, TX & thereabouts
    I'd be leery about pulling a trailer with a fifth wheel that had a bunch of cracks and rust spots like the one in the picture @Dennixx posted.
    @thelinedriver I'd ask the shop to see if the jaws are worn or if the locking mechanism is out of adjustment, in additon to findng the source of the metal fragments that you spotted.
  10. thelinedriver
    117
    72
    Dec 24, 2017
    Checked it before I left, it's a habit of mine to always look amd pull test before I leave
    mjd4277, hope not dumb twucker and 201 Thank this.
  11. TX2Day
    TX2Day Medium Load Member
    612
    4,098
    Apr 24, 2023
    Texas
    I have all connection points on trucks and trailers scoped every two years just for this reason. Metal does fatigue and will splinter and break apart. You were very lucky. So many people ignore the 5th wheel thump because they don't know what it is. I insist the trusted mechanic make that call. If it needs adjusted, great. If it needs other repair it doesn't move until those repairs have been completed.
