5th wheel problem?
Discussion in 'Freightliner Forum' started by Dobber2450, Oct 2, 2018.
  1. Dobber2450
    Dobber2450 Bobtail Member
    13
    Feb 15, 2018
    So I just got emptied and rehooked to my trailer, I'm driving to the gate and put the brakes on and feel a big thud. Almost felt like getting rear ended, but it felt like it was underneath me, like under the seat. I know the title says 5th wheel, but I can't think of what else it would be. I only know what they taught in the school I'm no mechanic. I've been feeling it here and there for a while now. It hits harder when it's empty so obviously the weight plays a big part in whatever sliding around down there. When it's heavy there's more resistance and isn't as noticeable. Any help is greatly appreciated
  3. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    You may have alot of play in the 5th wheel jaws. May be too much slop. It may need to be adjusted. Hold the trolley brake and try to move the tractor forward and reverse. See if you can feel any movement.
    stillwurkin and BUMBACLADWAR Thank this.
  4. Kyle G.
    Kyle G. Road Train Member
    3,903
    20,582
    Jan 23, 2016
    Eastern Iowa
    Let’s start with the obvious... did you visibly make sure the 5th wheel was locked properly before taking off? Are the slider pins on your tandems locked properly? You would be amazed how many people don’t check these things.
    stillwurkin and shogun Thank this.
  5. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Your 5th wheel jaws need to be adjusted and tolerances checked with a King Pin Fifth Wheel Tool, if it can't be adjusted within specs, the fifth wheel jaws will need to be replaced as they're worn.
    Dobber2450 Thanks this.
  6. shogun
    shogun Road Train Member
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    Bet the tandem pins are unlocked.
    BUMBACLADWAR Thanks this.
  7. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Ok...so Same trailer..Wasnt knocking or pushing you before the rehook? Like others said,check those tandem pins,for lock in & make sure the frame holes arent "augered out". And make sure youre not "high hooked on 5th wheel plate(no gaps above plate& get behind there and make Sure bar is across. JMO
  8. Dobber2450
    13
    Feb 15, 2018
    All pins are locked. It doesn't just happen after a load or unload. It happens in the middle after days of not touching anything. And yes I always check the jaws. I have checked for play by rocking it with the trolley valve down and didn't really notice anything. Now that it's empty I can definitely feel it. How serious is this? Do I need to worry about my trailer blazing it's own trail off the freeway? Lol
  9. Dobber2450
    13
    Feb 15, 2018
    Didn't really notice before when it was heavy, tried it again empty and I can definitely feel it.
    Hegemeister Thanks this.
  10. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Just give it a turn to tighten it and see if it helps, thatll answer your question a lot quicker and cheaper than anything on here.
  11. Dobber2450
    13
    Feb 15, 2018
    Company truck, I'm not touching it unless I know 100% what the hell I'm doing lol
