6.93 pm
Discussion in 'Experienced Truckers' Advice' started by wedge542, Nov 19, 2014.
  1. wedge542
    wedge542 Light Load Member
    241
    31
    Aug 13, 2007
    roll tide
    [TABLE="width: 100%"]
    [TR="class: EvenRowCompact, bgcolor: #ECECEC"]
    [TD]11/20/2014 0800
    11/21/2014 0800 [/TD]
    [TD]MEMPHIS, TN
    TULSA, OK [/TD]
    [TD]194
    [/TD]
    [TD]48FL [/TD]
    [TD]T [/TD]
    [TD]$2,750.00 [/TD]
    [TD]397 [/TD]
    [TD]$6.93 [/TD]
    [TD]5,000 [/TD]
    [/TR]
    [/TABLE]
    looks good right, 5000lbs 6.93 pm, got details 24ft long 12.20 wide, that little .20 requires a escort in front in ark, if not for prob 2 pieces of crate over the 12ft mark woulda been a good load keeping it under 12ft max and only permits/flags/ect to move it,amazing how 2 inches can change the ballgame.
  3. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Ouch
    This is why I dont play with you big boys doing the big over size.
    I'll stick with the occasional 9 - 11 ft wide and even rarer over weight permits.
    You guys are way above me on that stuff. I dont have the setup to run what you guys do.
    :biggrin_25514:
    Hurst:smt111
  4. wedge542
    241
    31
    Aug 13, 2007
    roll tide
    i realy want to knock the end pieces off the crates to get it to 12 even,lol
  5. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I had a load offering like that, shipper sent me a picture of load and it has about .5 inch of wrap on each side. Told um it would be cheaper if they removed the 1 inch of packaging so they did...I didn't end up needing an escort and got a pretty good rate. Luckily we got it adjusted before getting all the permits.
  6. 1boater12
    1boater12 Bobtail Member
    7
    4
    Nov 19, 2014
    I need to try OD someday.
  7. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    It not hard, just keep it in the paint like you would with any other load. You need to read your permits and follow the correct route. Also need to coordinate with escorts if needed and only run certain times of day. Still, the pay generally makes it worth it....although i have refused od loads that did not pay much more then non o loads.
    The hardest thing about OD is getting all your paperwork in order.
  8. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,186
    May 12, 2012
    SouthEast Alabama
    I have never pulled OD and don't want to, but I'm curious about this: who pays for the escorts(s) and permits? Does the shipper pay for that stuff, in addition to what the load pays, or would all of that come out of the $2750 on this particular load?
  9. wedge542
    241
    31
    Aug 13, 2007
    roll tide
    comes out of the 6.93 cpm, you always quote the haul for everything, permits escorts ect unless its a direct ship then you can work that with the shipper as you go.
  10. 88 Alpha
    5,595
    18,186
    May 12, 2012
    SouthEast Alabama
    Man, those big numbers don't look so big anymore. Thanks for taking the time to reply.
  11. Raezzor
    Raezzor Quis custodiet ipsos custodes?
    1,412
    1,186
    Aug 1, 2009
    Columbus, OH
    Nice thing about doing oversize is you do get plenty of sleep for the most part. Especially in the winter since you mostly can't run at night. Or in adverse weather that reduces vision. Or during rush hours in cities. Or on most holidays. Or most of the weekend, depending on the state. Or because constructions has the only route you can fit down shut down for a couple months. Or.... well, you get the idea. So ya, that $7 per mile looks great on paper but it can quickly become a load that it might have been better just to take that $3 per mile load. But then, I suspect alot of us who have done OD don't do it purely for the money.
    88 Alpha Thanks this.
