6 speed mack trans
Discussion in 'Experienced Truckers' Advice' started by stabob, Nov 5, 2011.
  1. stabob
    stabob Heavy Load Member
    862
    483
    May 25, 2011
    Sebring Fl
    Anyone ever had to drive one of these things? I have drove 10's and 13's for the past ten years so I thoght this would be a peice of cake but holy crickit droppings!! I have not felt like that in a long time!! Like i must look like I dont know what the hell im doin!
    I had to drive this truck for my road test for my new job.
    Any way I geuss this is my ''new'' truck so I know within a week or so ill have it down but any tips on this p.o.s would help. it just dont want to go into the next gaer without clashing and grinding.
    Thanks guys,
  3. Pedigreed Bulldog
    7,737
    14,425
    May 7, 2011
    A 6-speed is going to have a lot larger difference in RPM's from one gear to the next than a 10 or 13 speed.
    http://macktrucks.com/assets/mack/Datasheets/Transmissions/Updated041508/T-306G1361303.pdf
    There's a "shift chart" near the bottom of the .pdf, but basically you are going to:
    Run 1st gear to 1800 RPM...it'll slide into 2nd at 1000 RPM
    Run 2nd gear to 1800 RPM...it'll slide into 3rd at 1100 RPM
    Run 3rd gear to 1800 RPM...it'll slide into 4th at 1150 RPM
    Run 4th gear to 1800 RPM...it'll slide into 5th at 1200 RPM
    Run 5th gear to 1800 RPM...it'll slide into 6th at 1300 RPM
    Downshifting is the opposite...slow down until your RPM's are 1000-1200 RPM's and rev it up to 1800 to slip it into the next lower gear.
    stabob and heyns57 Thank this.
  4. stabob
    862
    483
    May 25, 2011
    Sebring Fl
    Thanks thats kinda what i was thinking i only drove it like 1 or 2 miles so i did not get to play with much. I will just have to get uesd to the higher RPM's Ive always babied my trucks shifting around 13 14 and 15 hunderd RPM
  5. Pedigreed Bulldog
    7,737
    14,425
    May 7, 2011
    It's probably got a Maxidyne under the hood....wide power band suited for this type of transmission. Drive it like you stole it.:biggrin_25525:
  6. stabob
    862
    483
    May 25, 2011
    Sebring Fl
    Yeah it does. i drove one b4 i think it was a 98 model year with a super ten seems like that truck liked it when you beat on it!!
  7. Lonesome
    Lonesome Mr. Sarcasm
    11,794
    24,641
    Dec 15, 2007
    Northern Indiana
    Drove some years ago. I remember you had to shift like a granny, nice and slow, or it would grind.
  8. king Q
    king Q Road Train Member
    2,881
    3,047
    Jul 26, 2010
    Johannesburg sa
    We used to have them hooked up to lowboy trailers at 135 000lbs.
    There was very little up shifting on a grade.
    When we got the 10 and 12 speed Mack transmissions we were over the moon.
    I think they were okay so the straight trucks though.
  9. cc tanker
    cc tanker Medium Load Member
    361
    214
    Jan 21, 2011
    drove many 2 stick sixes only one airshift six....shifter slow, lugger down low.....very good transmission once you get the hang of it you wont want anything else (IMHO)..old timers used to say you could eat a sandwich between gears ....it will help to pull your rpms down if you shift with the dynatard or jake on...
  10. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    yep they are a pain for us that grew up on 10's and 13's and what not. like the man said shift eat a cookie and shift again,
  11. mustang190
    mustang190 Road Train Member
    2,899
    6,270
    Jan 18, 2011
    Florida Panhandle
    We still have a lot of Macks with them, their not bad once you get the hang of them, run up the rpm and let it drop down to under 1200 then shift.
