6 speed vs. 10 speed differences
Discussion in 'Questions From New Drivers' started by TurtlesLikeI, Aug 13, 2018.
  1. TurtlesLikeI
    TurtlesLikeI Light Load Member
    238
    154
    Oct 13, 2015
    Nevada
    Hello, could someone explain to me what to expect between a “normal” semi 10spd and what I assume is a medium duty eaton 6spd (it’s a smallish medium duty tanker/fuel hauler).
    I have a road test tomorrow for a company and I’m pretty nervous about it because I’ve only driven a 10spd and that was almost 2 years ago because my former company gave me an auto after orientation.
    Does the 6spd still need ‘rev matching’ on downshift? Does it shift more like a car with the clutch pushed all the down, or a truck with it only pushed down a tiny bit?
  3. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    6 spds usually have syncros, more syncros, so you can single clutch it like a 4-wheeler. Floating is not recommended. rev matching helps but it is more tolerant anout it than a 10spd.
    TurtlesLikeI Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    You don't float the 6 speeds. But you don't ram them through like a car shifter.
    Take a heartbeat or two as you get from one gear to the next with appropriate RPM's which I imagine will be much larger in range than a big truck.
    Its taking a nice staffer for a drive test. Im not nervous about that. It's what you do not yet know or have not yet learned is the stressor here.
  5. Ridgeline
    22,740
    123,638
    Not all 6 or 6+1 have syncros. Double clutch is your friend.
  6. okiedokie
    okiedokie Road Train Member
    13,929
    110,463
    Jun 13, 2011
    PNWET
    That's the way I drive the wife. I'll be here till beer 30.
    Lepton1 Thanks this.
  7. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Treat it basically the same as a 10 speed. Cept no splitter. Least not on any 6 pack I've seen. Easy money
  8. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Eaton synchro 6 has to be used with single clutch like driving a car. It’s is a terrible trans and if it’s just a few years old the synchros will be trashed anyway so either double clutch of float then if the thing is grinding while trying to put into gear
  9. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    The medium duty 6 speeds that I drove you need to use the clutch.
    You need to double clutch and just take your time when you shift and it will fall right into gear.
    If you try to shift quickly or you are in a hurry you'll have a problem.
    If you know how to drive a manual transmission you won't have any problem. Like I said just take your time and double clutch and everything will work out for you.
