6 tires and counting
Discussion in 'Ask An Owner Operator' started by 86scotty, May 4, 2023.
  1. 86scotty
    86scotty Road Train Member
    4,707
    12,918
    Aug 27, 2017
    Appalachia
    I made a 2.5 day 1400 mile round trip from home starting this past Monday morning. Clean pretrip. No problems. I generally check my tires about every two days, and certainly before i leave the house at the first of any week/trip. Trailer has auto inflation, tractor checked manually by gauge, not by thump.
    Run was smooth. I probably pulled to the shoulder twice on entrance ramps to grab a snack or take a leak, nothing unusual. Where this run is there are a couple of very long stretches with no good places to stop or rest areas so you do what you gotta do. Did my 10's in in a rest area and next one in a truck stop, no parking on shoulder.
    Anyway, Wednesday morning I wake up 2 hours from delivery (near home, it's a round trip). Did a quick walk around in the dark and when I got rolling I had my trailer inflation light on. Stopped and looked at everything, couldn't find or hear a thing. Rolled on carefully since I was relatively close to home.
    One hour later stopped for fuel and realized I had a drive completely flat and off the bead. Made no noise. Light load. Really pissed me off that I missed it and I'm not sure how long. I was on a tight schedule and I called about 3 places trying to get in for tire service and everybody was swamped. Since I was close to home and light I decided to limp on in carefully, drop my load and then get the tire fixed.
    Problem is the delivery was past my favorite tire guys and close to my house so I decided to just head home and deal with it later since I had some stuff to get to at home. I park my truck at home and come back this afternoon (24 hours later) and ALL FIVE right tires are completely flat. Every one. All right drives and my right front steer. There is no way someone did this. As in, it wasn't vandalism or anything. It's secure where I park and I already knew i had one drive flat. Also, I know I've likely got at least one trailer tire flat because the light was on during my last leg home like I said above.
    I pulled all tractor tires this evening and am taking them in tomorrow. WTF? I have never seen this. I can't see anything in them but I was humping to get them dismounted at dusk. Hoping for the best tomorrow. I'm afraid to go check my trailer where I park it. I hope I don't find 4 more f'n flat tires on the right side.
  3. Ffx95
    Ffx95 Road Train Member
    1,370
    2,635
    May 18, 2017
    Probably picked something up from being stopped at the shoulder. Did you see any nails in the tires?
  4. 86scotty
    4,707
    12,918
    Aug 27, 2017
    Appalachia
    I saw a couple of small things that I marked with chalk but no big nails or anything. I'm wondering if maybe I hit some cable? I didn't hit anything on the road though, that I know of.
  5. PSM379
    PSM379 Heavy Load Member
    953
    3,987
    Apr 19, 2019
    Interesting do you have the flow thru valve stem caps? I had a trailer tire dead the other day that was 110 day before or so, I am always checking with guage. So I aired it up, week later still holding fine. I’m wondering if these caps leak sometimes
    Siinman Thanks this.
  6. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    Box of something on the road.
    86scotty Thanks this.
  7. 86scotty
    4,707
    12,918
    Aug 27, 2017
    Appalachia
    I do but I haven't had any trouble with those in a long time. And it really wouldn't explain 6 complete flats all at once.
  8. Arctic_fox
    4,509
    25,489
    Sep 16, 2016
    Gotta be careful of those shoulders. Cant tell you how many times ive seen people sweeping out trailers or random junk there. Good chance something like say a pipe or hell a metal rake was partially burried and as you ran over it it punctured every single tire on that side.
    Had that happen to me once a few years back. Had the red dot of doom then the stop engine lights come on. Pulled onto the shoulder when the truck did a auto shutdown and there was a box of roofing nails on the side i didnt see till i got out to insoect the truck. Flattened every single tire on the right side.
  9. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
    I parked on shoulder to check my load. In between my drives was the steel "T" post that are the base for the white roadside markers.
    The post was busted off at ground level with several sharp points sticking up.
    I had to back up to clear it to leave.
    Lucky for me I usually do a walk around whenever I stop.
    Good chance I would've punctured 1 drive and 2 trailer tires if I didn't see it. If it would have been night I probably wouldn't have seen the busted post.
  10. Beaver9
    Beaver9 Heavy Load Member
    966
    1,183
    Jun 15, 2020
  11. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,478
    Mar 18, 2021
    St Malo mb
    One day I saw about 25 cars and trucks on the shoulder with flats and busted rims . I saw a busted bridge joint in time to avoid it
    Those ones didn’t . If your auto inflation didn’t mess up and let air out it’s pretty crazy you have side by side tires flat . Even with nails they drain at different paces.
