60 series 12.7
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wtwfarms2018, Feb 21, 2024.
  1. wtwfarms2018
    wtwfarms2018 Bobtail Member
    Feb 21, 2024
    I have a 12.7 ddec 4 that I replaced the head on. Truck was running before I changed it. Put new injectors and new cam in it. Set cam gear back in same position as it came out. The ECM is not sending power to injectors to fire. Changed injector harness, changed sensor harness, replaced TRS & SRS sensors. Sent ECM out and had it gone through. Its showing oil pressure code (inactive). I changed TRS sensor again and for some reason got rid of oil pressure code but have a engine position sensor code. Put old sensor back in and oil press code comes back and no engine position sensor code. I can't figure out why this thing wont run. Checked all power and grounds, and ohm'd new sensor harness
  3. Big Road Skateboard
    7,096
    40,277
    May 2, 2021
    You are able to hook a laptop to it? Verify that after cranking it shows SRS Received as Yes.
    Did you run the overhead, and did you turn the engine over when the cam gear was out?
    Rideandrepair Thanks this.
  4. wtwfarms2018
    Feb 21, 2024
    So I did forget to mention, hooked DDL up and the ecm isnt reading rpms. ran overhead, engine did not move before re install
  5. DDguy
    DDguy Light Load Member
    157
    101
    Apr 21, 2020
    Ont. Canada
    So this engine will not fire unless it sees both TRS SRS once its running if it looses one it normally stays running untill you shut it off
    Have you checked the Bull gear for play ?
  6. Rideandrepair
    17,559
    56,887
    Aug 8, 2015
    Have you primed and pressurized the fuel tanks? Won’t do it simply by cranking.
  7. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    I know next to nothing about a Detroit, but have you checked fuel pressure while cranking?
    I know some engines will not fire the injectors until a minimum pressure is seen.
    Vampire and Rideandrepair Thank this.
  8. DDguy
    157
    101
    Apr 21, 2020
    Ont. Canada
    This is not the Case on detroits but yes there needs to build a few psi in the head for the injector to deliver fuel even the the ecm opens injector
  9. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    hit it with a shot of starting juice takes awhile sometimes to get the air out of the head!
