60 series coolant pressure building, what is causing it?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 9200detroit, Nov 22, 2021.
  1. 9200detroit
    9200detroit Bobtail Member
    5
    Nov 22, 2021
    I have a 2000 60 series thats getting pressure in the cooling system, no oil in water or water in oil, and bypassed air compressor so thats not it either. I pulled the head and cant find the gasket being bad. Wondering what I should be looking at instead
  3. AModelCat
    165,056
    Any air operated HVAC controls on the truck?
    Big Road Skateboard and Magoo1968 Thank this.
  4. 9200detroit
    5
    Nov 22, 2021
  5. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,082
    Sep 24, 2019
    Raleigh, NC
    Guessing no fuel was mixing in oil or coolant?
  6. 9200detroit
    5
    Nov 22, 2021
    No cant find any fuel in oil or coolant
  7. Brandt
    Brandt Road Train Member
    4,635
    6,376
    Sep 17, 2012
    I had 1999 S60 that was rebuilt at 1.1 million miles. They put a rebuilt head on as part of the job. After two week it was blowing coolant out the plastic holding tank. But only when pulling a big hill and engine would get up to 208+ F coolant. Took to another Detroit Diesel shop, they had put truck on Dyno and simulate pulling a hill. They found the rebuild head had a crack the only open when coolant was 208+F
    little cat 500 and Rideandrepair Thank this.
  8. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    The gasket was intact when you pulled the head? I can’t understand how you can tell it wasn’t leaking. Check the liner heights. I think it’s .01-.05 thousand, with no more than .02 between 2 adjacent cylinders. Get the head pressure checked. Might as well do an inframe now.
  9. WrenchWrenchWrench
    WrenchWrenchWrench Light Load Member
    131
    118
    Jan 3, 2016
    Check liner protrusion and have the head checked for cracks while its off.
    Rideandrepair Thanks this.
  10. 9200detroit
    5
    Nov 22, 2021
    Ending up doing an inframe, anyone got any info on pai brand kits, are they good and where are they made. Thanks
  11. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    I avoided them myself. Everyone has a different opinion. I used FP Diesel (Federal mogul). I’m happy with it. My first choice was Mahle, but they were behind on orders. They had just bought Clevite bearing, and re doing their part #s or something. Mahle makes the original pistons. Both are good kits. FP was a bit less. Also used a DD reman head through Freightliner Dealer. I was told to avoid aftermarket heads. Some have been found to be milled too much. Detroit kits don’t come with rod bearings. Aftermarket kits do. Bearings are another $350, plus core deposit. Detroit does research on old bearings and heads, so I’ve been told by an Engineer at Detroit.
    RubyEagle Thanks this.
