60 series coughing between shifts under load
Discussion in 'Freightliner Forum' started by NorCenArk, Dec 10, 2013.
  1. NorCenArk
    NorCenArk Light Load Member
    76
    35
    Mar 31, 2011
    Russellville, AR
    I have a 2007 freightliner century with 60 series detroit with egr only. Under a load upshifting, when the rpms go down to about 11-12 hundred the engine wants to cough until i get the rpms back up. Anybody knows what causes this?
  3. Jaguar115
    Jaguar115 Heavy Load Member
    787
    757
    Apr 4, 2008
    Warsaw, Mo
    I had that issue with a classic. . Could hear the engine cough back through air breathers. .
    Everybody kept telling me they couldn't simulate it. .I guess that I finally found a freightliner dealer that needed work. .. There was a bulletin out about rebuilding the head. . That fixed it.
  4. Dewey120
    Dewey120 Road Train Member
    1,025
    456
    Mar 17, 2010
    Southern California
    I had this same problem and it was my egr valve. Just look there to see if you see any soot or by the input/outputs of the egr cooler. I have the exact same engine as you do (2007 Freightliner Century).
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Almost everytime i have had this problem on detroit with egr it has ended up being the turbo i would check youre egr to but there is severe loss of power if the egr is stuck open also check if u see a severe amount of black smoke coming out the stack when u really get on it this is actually a common problem for detroit
  6. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Turbo Actuator valve, not opening quick enough to spool up the turbo so you get a "cough". Really isn't a fix, they just keep throwin' new ones on and hope it works. doesn't hurt anything but just annoying.
    NorCenArk Thanks this.
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    EGR valve stucks, to fix it I had to take it apart and clear soot with solvents
  8. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Mine does it too.
    New EGR valve due to a EGR Valve code. No difference.
    Thinking it's a turbo issue on mine, now to get the dealer to fix it under warranty!
    Martin
  9. bad-luck
    bad-luck Road Train Member
    3,450
    6,366
    Nov 16, 2013
    Baltimore, Maryland
    Could be a leak in air charger system. Bad delta p sensor dirty tubes from delta p to egr cooler. Vent vaccines sticking in turbo
