62" sleeper with 238" wb; top long?
Discussion in 'Ask An Owner Operator' started by IH Branded, Feb 11, 2017.
  1. IH Branded
    IH Branded Medium Load Member
    412
    104
    Jun 4, 2013
    Great Lakes area
    Finally found a newer truck like I want but is this wb too long? Seems 15-20" longer than most. Be any advantage?
  3. CJndaTruck
    CJndaTruck Road Train Member
    3,349
    3,365
    Nov 21, 2014
    Knoxville, TN (area)
    If you pull flat it is what you want. Bit long for van.
  4. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    It's fine. The truck will be a little more versatile for you.
    Big_D409 Thanks this.
  5. IH Branded
    412
    104
    Jun 4, 2013
    Great Lakes area
    For instance?
  6. IH Branded
    412
    104
    Jun 4, 2013
    Great Lakes area
    Van sometimes? Too much air gap?
  7. CJndaTruck
    3,349
    3,365
    Nov 21, 2014
    That would be the prob for a van. But as mentioned if you pull anything else you might want that.
  8. special-k
    1,523
    3,258
    Dec 27, 2008
    Headache rack, Hose rack, tool box? Some states give a little more weight depending on overall length, could end up pulling a flat etc. There's more options to trucking than just pulling a van.
  9. Big_D409
    Big_D409 Medium Load Member
    552
    729
    Dec 1, 2012
    Robertsdale, AL 36567
    Wouldn't say it's too long for any application. Mine is a 232" WB and that's with a 77" sleeper. My father currently runs a 260" WB, pulling dry van and reefers.
    All about how your setup is when maneuvering. Unless the space you are trying to fit into is physically smaller than your combo.
  10. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Definitely not too long.
    Even with 379 a common truck in Canada was 63" sleeper with 244" wb. An excellent setup for weight distribution and not so long a wheelbase it is difficult to drive. We are limited to 244 without permit - for another discussion.
    That should be a good truck. Get bunk extenders if you want to close the gap a bit.
  11. IH Branded
    412
    104
    Jun 4, 2013
    Great Lakes area
    Thanks everybody
