6nz c15 engine fan on temp?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 6nz389, Dec 5, 2017.
  1. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    When you boys say your fan kicks on before the set in stone temp all cat ecm's have it isn't coolant temp that is doing it. It is more than likely the air intake temp that is causing the fan to kick on sooner.
    cmrdev, Oxbow, SAR and 1 other person Thank this.
  3. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    True.
    Intake air temp will turn the fan on also.
    As far as water temp goes tho it is 217.
    Some of the older low nox files in the 40 pin ecm engines ( 5ek,6ts and 1lw ) had fan on temp at 205 .
    Oxbow Thanks this.
  4. Dubbs
    Dubbs Bobtail Member
    31
    28
    Dec 31, 2015
    My gage shows about 210-215 when the fan kicks on, but what the gage shows and what the ecm sees can be two different things, especially if you have an older gage or the senders are different ages.
    What I’m getting at is, let the shop heat cycle the engine to make sure the fan comes on, then once you know it’s good, see what the gage says the next time the fan turns on.
    Hope that helps
  5. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    103 C for coolant temp to cut fan in 73 C inlet air temp to cut fan in or A/Con high pressure switch will also cut fan in on the Cats.
    quite often the "truck" gauges are reading different to the ECM sensor
  6. 6nz389
    6nz389 Light Load Member
    54
    45
    Nov 14, 2017
    I got the fan working, they had to change some things around in the datalink between the cab and ecm (08 truck). Don't know if it kicks on with the AC high temp because my ac is currently disconnected, but the fan kicks on around 215°f and back off around 95°f
