6nz on short steep grades
Discussion in 'Ask An Owner Operator' started by killer120, Apr 3, 2022.
  1. killer120
    killer120 Light Load Member
    70
    43
    Jul 1, 2013
    Was curious what everyone's braking technique is on short grades with a cat engine? For me if it's less than a mile I snub it down. If it's 2 miles or less I drop down to 40 and snub from 40 to 45 Jake's on of course. Anything over 2 miles I drop down to 25 so the Jake's fully hold me. I run mostly west coast and there's quite a few short steep grades going through Washington and Oregon and parts of Cali.
    D.Tibbitt Thanks this.
  3. staceydude
    staceydude Road Train Member
    1,150
    5,029
    Apr 3, 2020
    I’m just jumping in to listen and see how others do it (I have a 3406E 5EK so I’m sure it is the same)
    What is your average gross weight?
    D.Tibbitt and Crude Truckin' Thank this.
  4. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    I just haul as.s. and hope for the best. :dontknow:
  5. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    Heck, I toss it in neutral for fuel economy.
  6. Last Call
    Last Call Road Train Member
    7,568
    45,913
    Mar 15, 2021
    Dude.. not to be a DICK .. but I have never seen a set of Cat Jake's fully hold you back ..
    But there's got to be alittle truth to what your saying because unless your a Cat with 9 lives your still alive to post about it ..
  7. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    Lol, did that once on accident. Trans was on the fritz for awhile and it popped out of gear. Was a pretty scary ride actually. That was in WY years ago.
  8. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    Sure, mine will hold me back no problem if I'm going so enough. I just go between 2 and 3 to keep my speed. If weight wasn't as much of a factor on this truck, I would put a klaam brake on it. I love those things.
    D.Tibbitt and Last Call Thank this.
  9. Hammer166
    7,605
    27,793
    Aug 18, 2007
    ~8600+' and loving it!
    I would answer that it depends on what you consider acceptable brake lining life. Consistently holding a loaded truck back on steep grades is going to really take its toll on the linings.
    The other consideration is how hot are the linings at the bottom? Are leaving yourself in the situation where your brakes have little to offer if you have to stop suddenly? Yes, in days gone by, that was SOP with no Jakes, but depending on traffic conditions, the reduced stopping ability may not be worth the little bit of saved time.
  10. Last Call
    7,568
    45,913
    Mar 15, 2021
    We just had this discussion couple days ago in another thread.. anyhow.. I have brake savers on both my trucks .. Iam quoting myself.. ( I would give up both my testicles before I would give up my brake saver )
  11. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    To me, Jake's with the Klaam is the way to go. However, I don't have the weight to spare on this truck. To me the problem with brakes saver is wear and tear on oil and they are prone to leaks, but they do a good job. Not denying that.
