6nz rpm when upshifting and downshifting?
Discussion in 'Ask An Owner Operator' started by Reaper'sTrucking, Jun 28, 2023.
  1. Reaper'sTrucking
    Reaper'sTrucking Light Load Member
    79
    73
    Jun 1, 2020
    What rpm do you guys upshift, downshift and cruise at with your 6nz? I have an 18 speed I usually upshift at 1500, downshift at 1200, running hills with 100k plus I usually keep it between 1400 and 1700
  3. Big Road Skateboard
    7,100
    40,318
    May 2, 2021
    I'd think 1400 down and 1600 up woukd perform a lot better with that engine
  4. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Depends on rears and tire size
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    The 6nzs ive run kiked 1400-1600 pretty good, 1250 and under was too slow, 1700+ was just wasting fuel (uphill heavy could be its own thing, my current 6ts with its gearing and trans needs 18-1850 sometimes). I got comfortable with 1350, engine seemed happiest cruising at that rpm, lowest noise, best mpg
  6. abyliks
    abyliks Road Train Member
    4,123
    9,716
    May 2, 2010
    ludlow MA
    Fuel shutoff should be 2150, I’ve pulled some heavy stuff with yellow motors and much below 1400 rpm the pyro likes to start going the other way
    Big Road Skateboard Thanks this.
  7. Reaper'sTrucking
    79
    73
    Jun 1, 2020
    That's how it was when I hauled construction equipment, start getting upwards of 180k+ really starts to show what the engine likes, always kept it between 1500 and 1900
  8. Cdemars316
    Cdemars316 Road Train Member
    1,037
    6,699
    Nov 10, 2018
    I do about the same usually like to cruise around 1300-1400 shift around 1500. I watch the hell out of the pyro though, she gets hot in a hurry below 1400 or so. But 90% of the time I am cruising right around that. Wind is the game changer fighting a headwind or 3/4 wind and I will keep it in a gear to stay above 1500 to keep the temps down
  9. Derailed
    Derailed Road Train Member
    2,384
    2,657
    Dec 10, 2008
    Upstate NY
    Depends, I usually upshift around 1700. Cruise and pull grades at 1500 and not much below. 3.58 gears and 22.5. I do alot of stop and go and still manage 5.7 mpg
