6th times the charm?
Discussion in 'Questions From New Drivers' started by THeGAME, Nov 11, 2014.
  1. THeGAME
    THeGAME Bobtail Member
    20
    21
    Nov 11, 2014
    Hello!
    So far, my experience has been a nightmare. Im going in for my 6th test Friday.
    Getting the CDL permit was easy. I went in and took the computer tests with very little study. It was only $25, so after a few days of study I went in and passed them all. It got much more difficult from there.
    Im self certifying and being trained on route by a driver who is retiring and selling me his truck and trailer. I am not attending a school. Ive got lots of driving experience in the real world over the last two months. Unfortunately, this has little to do with passing the skill tests. Ill give you a so far so that you fellow noobs can avoid some mistakes..
    My first attempt was kind of a joke. I got my CDL handbook from the DMV two months before I took my first Skills test. I went in pretty confident and found I didnt know jack. However, the biggest problems were I didnt know the testing procedures, and they had changed 102 items in a new drivers manual a month after I got mine. I really didnt have a chance after that. $100 down the drain. On the second attempt, while I was doing the air leak tests, I watched as the trailer pressure lost 10psi in 30sec. The ABS regulator went out. Equipment failure. I got the next test free, and they failed the equipment again due to no license plate on the tractor. Another $100 gone as only two equipment failures per test. So I decided to use another owner operators trailer because I wanted to be sure everything was ok. Wouldnt you know it, another air leak!!
    At this point, I was pretty miffed. I decided to call a CDL school and rent some equipment. At the cost of $380 for an hour of instructor time and truck rental, I went in and failed the air test again. This time to giving the wrong ranges on the valve pop out. I said 20 to 40psi. It was 20-45psi. Another $100. Next at bat with the rental equipment, I failed the walk around pre trip. I pointed to and gave descriptions of every single part that was required but was not descriptive enough.
    Anyway. Here are some of my boo boos. Try and avoid these if you can..
    1. If you are being trained by a "Salty 'Ol Dog" who has been driving for decades, and not a school, its a good chance they would fail the tests. All of them. They can teach you a lot about the real world, but you arent learning about that at this point. You are learning to pass a test. As said before, they arent the same thing. You will probably hear "You dont need to know that" more than a few times. Well let me tell you, you need to know what is in that handbook to pass. Be gental but forceful when talking to the 'Dog and explain and let them rant about their years of experience and knowledge. Then do what you need to do to pass the test.
    2. DO NOT USE A FULL SIZED SLEEPER/53' TRAILER FOR THE CONTROL SKILLS TEST IN WA STATE.
    I dont know about other states, but the testing course is not big enough for a full sized combo. Even the testers asked what I was thinking bringing one in there. It was all I had until I rented a smaller set. Due to my real world experience, I probably could have passed, but it would have cost a lot of points in encroachment. Make it easy on yourself.
    3. You will be giving a lecture to the tester on your pre trip. They tell you to begin and thats it. So come up with a little script on your pre trip.
    4. Be discripteve during your pre trip using all of the words in your manual.
    Yes, you really do need to say "Properly mounted and secure with no loose or missing nuts, bolts or clamps. Not bent broken or cracked. Not Leaking. Hoses are secured with their clamps and fittings. The hoses are not abraded, cut cracked or chaffed, not leaking. Not rubbing or excessively warn. Is gear driven". You have to be specific. Be ready for it. I wasnt.
    5. Make sure you pre trip the vehicle before you go to the test site. If there is a problem with it, reschedule. Do it yourself and dont rely on the Salty 'Ol Dog, even more so if he owns the vehicle. Experienced drivers will run with problems that you will get disqualified for and not even know it. In WA you get two equipment failures before you have to pay again. Make sure all is up to snuff and there are no leaks, broken lights or anything else that will fail the vehicle.
    6. Although I didnt attend a school, I paid an hour to get with an instructor. If you are self certifying, It will be profoundly helpful. They will tell you what the testers are looking for and point out issues with your driving and pre trip. For me it cost me $130 an hour. After just an hour I am far more confident going in for what I hope is my final test, lol. They have also worked me in for free backing with a 28' and pre trip training.
    7. Relax, take your time, and have fun.
    As you can see, not passing the test the first time isnt the end of the world.
    So, I havent even made it to the control and road tests. These are the least of my worries. The 'Ol Dog may not know how to pass the tests, but he can drive and back and has taught me well. The few things "I dont need to know" I have taught myself. The instructors at the school say I will do well.
    Any other advise from the experts? I always love to hear it, and have a few more days to absorb.
    Thanks!
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    the only thing schools teach you is how to pass the test
    but they do that well
    Vilhiem, rambler, Chinatown and 2 others Thank this.
  4. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Lots an old dog forgets and/or was never part of their testing.
    You've included #5 after $500, punishment served... I'd feel bad ripping on you now.
    Good Luck!
    Chinatown Thanks this.
  5. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Good luck Friday.How many more times can you take the test or is there no limit?
  6. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    THeGAME, that's an excellent post. I too regained my CDL without the benefit of going to a "CDL Mill". Failed three times trying to do the DMV test: once for bone heading the brake test, once for failing to say "inflation" instead of "air pressure" during the pre-trip, and once for being unable to see the cones during the skills test during a howling dust storm. I ended up taking my written test again to get another "3 strikes" on the DMV test and passed on the next try.
    Good to hear that someone else is going the "non-school" method of getting their CDL. As a TRAINER for a mega carrier I'd have to say I'm not impressed with how schools prepare students for the real world. It IS all about passing the test. They expect the REAL training to start after getting hired.
    Strange world indeed.
    Chinatown, hal380 and OriginalBigfoot Thank this.
  7. OriginalBigfoot
    OriginalBigfoot Light Load Member
    296
    181
    Oct 27, 2014
    New Orleans, LA
    Well you shouldn't have failed for saying 20 to 40 is where the spring brakes come on because that is correct. Around 40 in the summer and 20 in the cold -- notice the use of the word, around? 45 would be correct as well, since the baseline numbers are 20-40 with a degree of difference based on the vehicle of 10% or more. For them to fail you on this is ridiculous!
    I'm one of the old farts you're talking about, and when I got my license, we didn't have to do anything but check for air leaks and tires and then drive the truck! We backed into a dock, parallel parked, did a reverse serpentine and drove around town under all conditions. Drivers are not mechanics, and this is why we have gauges and idiot lights! Although you will learn a lot over the years.
    I was an instructor for a few years back in the 90s and that included being a state certified CDL tester. In the state training class here in LA, they will tell you that the person taking the test doesn't need to know all the *names* of the items they are inspecting, as long as they can point to it or touch it and say what they are inspecting for. For example, saying, "Checking this round thing here to make sure there are no air leaks, nothing is loose, missing or damaged, and it is secured to the vehicle and when I pull on this metal piece, this rod doesn't move more than an inch" (pointing at the different parts) would be a pass for the inspection of the brake chamber, slack adjuster and push rod on the tractor. You can confirm this with the tester *before* the test begins by confirming with them that you do not need to know the names; some states might be different.
    IMPORTANT! You NEVER do a PTI with the KEY in the ignition! Pre-PTI is as follows:
    1) On a flat surface, chock the rear outer tire (front and back) of your drives (Most schools or rentals have double chocks on chains in the tool box).
    2) REMOVE the key from the ignition and put it in your pocket.
    3) RELEASE the brakes.
    Even if your state doesn't require it, you never scoot under or between the wheels of a vehicle with the key in the ignition!
    There are a couple of tricks that going to a school might teach you to pass the PTI on the road test -- Acronyms and phrases!
    ABCD, wires, hoses, tires: Start with the word NO Abrasions, Bumps, Cuts or Dry rot.
    ABC BATTERIES: No visable Acid, Bulges or Corrosion -- Followed by, ABCD for the wiring.
    The entire phrase: Nothing loose, broken or damaged and the item is properly mounted, and all mounting hardware is present and secured.
    Signs of looseness: Nothing is loose, broken or damaged, nothing leaking, no rust trails or metal shavings and no shiny threads.
    (You can use signs of looseness on just about anything -- water pump, shocks, wheel fasteners, air hoses, brake chambers, etc.)
    These couple of things WILL get you through the pre-trip!
    But I have to say, in all my time as a CDL examiner, most did not fail the pre-trip; it was usually the Air Brakes section. Sure, everyone knows how to do a tug test and 5-mph test, but what most people fail on are the following two items:
    1) Forgetting to push the buttons in and release both brakes during the leak down.
    2) Forgetting to turn the key on during the fan down.
    Almost ALL of the seasoned drivers looking to recertify would fail one of these two, and after a while, I would give my, "Professional advice" speech at the time of the application and payment, advising seasoned drivers of the two reasons they might fail. This was both legal and ethical, as long as I did it before we got to the truck and started the test. Schools and testers love earning this extra money, and most of the people getting recertified aren't in the position to fork over $300 two or three times!
    So learn your acronyms and phrases to pass the PTI portion and remember the two reasons people fail on the air brakes and you'll be good to go!
  8. OriginalBigfoot
    296
    181
    Oct 27, 2014
    New Orleans, LA
    Air pressure and inflation is the same thing on a tire, the examiner was wrong. I had a similar story from someone I tested. He failed because he didn't tell the examiner that the tires on the duals were not touching at the bottom, or a possible fire hazard from the rubbing while driving. So I asked him, did he state that he checked the proper tire inflation of 100 lbs with a pressure gage? He said yes. And then I asked if he stated the rims were properly butted? Again, yes, so in this case, it would be an physical impossibility for duals budded properly with 3" of space between the rims to rub. I gave him the address and number for the CDL manager at the state and told him specific words to put it a complaint in writing. He came by and thanked me a month later when he got his $200 refund from the examiner that made the mistake.
    Exams are only given in fair weather conditions. The fact that there was a dust storm while you were testing, the examiner should have stopped the test, and rescheduled you for free, just like if it starts to rain.
    Unfortunately, there are a lot of people who get certified as testers and then get a Hitler complex! "Do it my way, or not at all!" I looked at it differently -- these were my compadres... brothers on the road, and when you spend enough time on the road, you'll know what I mean. We're supposed to help each other, not look for reasons to make people fail! Even though I couldn't offer advise during the tests, I was able to walk away! So when someone hit on all the points under the hood of the tractor on the driver's side, I would walk away to the passenger side. When they finished there (whether they knew it or not) I would walk to the rear of the tractor, and so on. It's really too bad that so many out there want to see you fail!
  9. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,301
    Nov 8, 2009
    The Highway To Hell.
    You failed your CDL test??? What the????? C'mon man really??? I never failed.... Except that one time and scraped by the second time..... Lol. You'll get it done. You're showing some determination right there. I wish you luck. Here's to you passing with flying colors!
  10. THeGAME
    20
    21
    Nov 11, 2014
    Thanks!
    As far as I know, there is no limit. Only what you can afford to keep paying for the new test dates, and how many 3 (pre trip/control) to 7 (road test) day reschedules you can wait. Also, your permit lasts a year, then you start all over.
    Bigfoot.
    Thanks for the advise. The school Im renting the equipment from, CDS, also gave me a pre trip list with acronyms, and cue cards to borrow. They really want me to pass, and I suppose the word of mouth is good for them.
    I wish I could use the acronyms, lol. I keep wanting to call bushings grommets..
    As far as the 20 - 45psi thing, in our states manual there are bulletized numbers and phrases, and they want all of those ranges specifically stated.
    Funny you mentioned the spring break though. The school Im renting from cuts the spring break out of their trucks so you arent asked about them or required to do that part of the cab test. But they disqualified me for a missing license plate. (*Head Shakes)
    One more thing Id like to mention.
    I agree that these requirements are ridiculous. To put it into perspective, the FED and State want things to be safe. Thats fine. However, I worked as a ramp rat at SeaTac airport for over 16yrs and very rarely did the aircraft get inspected mechanically. We brought them in, unloaded and loaded them and sent them out withing 2hrs. The only time a mechanic showed up was when a pilot requested them.
    pattyj Thanks this.
  11. Chinatown
    Chinatown Road Train Member
    77,777
    184,639
    Aug 28, 2011
    Henderson, NV & Orient
    Have you priced insurance for the truck you're buying from the retiring driver?
    Your insurance will probably be much higher than his since he's had a CDL for decades and you don't have one yet. Better make some phone calls and check the OOIDA website.
