70 hour rule/ 34 hour reset
Discussion in 'Questions From New Drivers' started by Sorenson, Nov 20, 2011.
  1. Sorenson
    Sorenson Bobtail Member
    Do you have to drive the full 70 hours before doing a 34 hour reset? Can I rollover my hours?
  3. georgeandson
    georgeandson Heavy Load Member
    890
    647
    Feb 18, 2011
    1 mile down the road.
    Go get a log book is you do not already have one and read it. This will answer all your questions and explain clearly what you can and can not do.
  4. 25(2)+2
    18,762
    46,074
    Sep 18, 2006
    the road less travelled
    The way things are now, any time you get 34 hours completely off duty, never going to lines 3 and 4 for the entire time, you reset your 70 hour clock back to zero in the eyes of enforcement.
    It effectively does away with recapping your hours if you don't run too hard and would not get that many hours in 8 days unless you can't get that many hours off in a row.
    It was chosen to disrupt regular hourly drivers as little as possible, you take your regular 10 hours off plus another whole day, and you are reset to zero.
    Wargames Thanks this.
  5. Sorenson
    Can rollover hours be applied to 34 hour reset?
  6. me only
    me only Medium Load Member
    309
    85
    Nov 9, 2011
    buford ga
    Drivers of property-carrying commercial motor vehicles involved in interstate commerce have an option that allows them to reset their accumulated on-duty time. This option, known as the 34-hour restart provision, says that once a driver has 34 consecutive hours off duty, he/she may "restart" the 7/8-consecutive-day period. After the 34-hour period, the on-duty hours worked before that 34-hour period started no longer have to be considered when calculating the driver's 60/70-hour limit.
    Article Source: http://EzineArticles.com/1025027
  7. DragonTamerBrat
    DragonTamerBrat Road Train Member
    2,742
    985
    Jun 6, 2011
    If by rollover hours, you mean the hours you get back at midnight, then NO. You have to be completely OFF DUTY and/or SLEEPER BERTH for a full 34 hours.
  8. Panhandle flash
    Panhandle flash Road Train Member
    5,597
    6,014
    Jul 18, 2008
    Oklahoma City
    Maybe you ought to give us your definition of "roll over" hrs. Like has been said, if you have a total of 34 hrs (lines 1&2 only), you've completed a reset and have a fresh 70 to run. No "roll over" needed. Now if your talking about running on your "recap", thats a whole nudder story and I'm sure that theres someone who can explain that better than I can!!!! :yes2557:
    Lilbit Thanks this.
  9. Svoray
    Svoray Medium Load Member
    558
    194
    Feb 3, 2011
    Texas
    You can reset the 7/8 days after 34 consecutive hours of off-duty...unless you're in the oilfield like me and reset after 24hrs. As for rollover hours, this isn't AT&T. Now there is some way of gaining hours back but not sure hour that works.
  10. Allow Me.
    10,788
    12,674
    May 28, 2009
    Rancho Mirage, Ca.
    If you complete a 34 reset, you now have a fresh 70 to work. You cannot have more than 70, so, forget about rolling over any extra. (I'm assuming you want to have 70 plus extra hours un-used from the previous 70)
    25(2)+2 Thanks this.
  11. 25(2)+2
    18,762
    46,074
    Sep 18, 2006
    Thanks for coming up with that explanation, it explains much.
