76 k100 won't shut off
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 76K100, Mar 27, 2023.
  1. 76K100
    76K100 Light Load Member
    55
    89
    Mar 13, 2023
    WISCONSIN BUT FROM NOR CAL
    anybody have any suggestions why my k100 won't shut off when I turn key to off position?
    Oxbow Thanks this.
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,770
    Mar 5, 2012
    Ontario Canada
    Does it shut off if you turn the taps off at your fuel tanks..
    76K100 Thanks this.
  4. 76K100
    55
    89
    Mar 13, 2023
    yes that's what I did I put an upgrade fuel filter and took the cap off and it finally shut down after all fuel ran out
  5. Oxbow
    Oxbow Road Train Member
    13,728
    142,421
    Nov 24, 2015
    Well, if the thumb screw is out it would have to be electrical. I am not Well versed on your wiring, but my second thought is a relay is sticking. If not that then a short between another hot lead.
    Perhaps others can help more.
    Jubal Early Times and BoxCarKidd Thank this.
  6. Deezl Smoke
    Deezl Smoke Medium Load Member
    546
    359
    Feb 12, 2011
    Hillsboro Oregon
    Cummins or detroit? By the looks of the avitar, cummins?
    If cummins, I think there is a solenoid on the pump that gets hung up. The 5.9 in the 1st gen dodge pickups does the same same thing. You might also try a cummins forum and see what the pu guys have doen about it too. A pickup with an automatic trans is a sob to get shut down when the key wont work.
  7. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    I'am not a Cummins expert but your fuel shut off solenoid is hung up open or you getting Constant power to it ..you should start by checking your power wire at the solenoid
    I would of put in 4th grear orso with the brakes set and let the clutch out to kill it vs shuting the fuel supply off .. now you gota work harder to get it to fire again ..
    Thats just me though
  8. OLDSKOOLERnWV
    19,292
    291,695
    Next time it does that leave the key off and and see if it quits in a few seconds, 10-15 seconds…..
  9. Oxbow
    13,728
    142,421
    Nov 24, 2015
    Quite a few posts deleted in this thread......or maybe it's just my phone.
  10. jaffles
    jaffles Light Load Member
    257
    580
    Oct 18, 2017
    Australia
    Warn ignition barrel/key? Think an auto electrician would take long to nail it down.
  11. Mnmover99
    Mnmover99 Light Load Member
    248
    344
    Oct 22, 2022
    The electrical wires break over time and the place they break is where the wires bend when you lift up the cab. Try running a new wire from the ignition switch to the engine to see if that is the problem. What engine? If it is a detroit, the shutoff kills the air or fuel, perhaps the mechanism needs adjustment.
    BoxCarKidd Thanks this.
