7th injector d13 leak
Discussion in 'Ask An Owner Operator' started by ddurmic88, Oct 18, 2018.
  1. ddurmic88
    ddurmic88 Bobtail Member
    Nov 12, 2014
    Thanks Received:
    2013 VOLVO D13. Happened twice in last month and half. Seems like large amount of fuel dripping inside and outside of 7th injector on defuser, smoking and dripping from exhaust clamps between flex pipe&defuser...does it for little bit then goes away... Went ahead and replaced new 7th injector. Did it for minute then stoped leaking and smoking.
  2. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    Dec 5, 2013
    1,899
    Thanks Received:
    1,923
    Maybe cracked injector or dried out o ring seal (toasted)
  3. OilBoomDreamer
    OilBoomDreamer Light Load Member
    Oct 18, 2018
    73
    Thanks Received:
    35
    Add a smudge of RTV sealant. Should be tip top in no time.
  4. Socal Xpress
    Dec 6, 2014
    1,855
    Thanks Received:
    1,958
    Los Angeles, Ca
    Wow.......2 times and that didn't seem important enough to have it fixed immediately? Kcuf it right!!! Let the insurance sort it out once the truck goes up in flames.
    Good times.......keeping up on maintainence is for seissup.
  5. Socal Xpress
    Dec 6, 2014
    1,855
    Thanks Received:
    1,958
    Los Angeles, Ca
    Burn baby burn!!!
  6. sirjeff
    sirjeff Medium Load Member
    Dec 1, 2013
    489
    Thanks Received:
    1,468
    West Kootenays, British Columbia
    Try a new gasket in between the down pipe and flex pipe in addition to checking the injector. That gasket fails on my truck every year.
    Easy enough to do - Just make sure the ring inside is seated properly when you put it back together.
