8/2 Sleeper Formula
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Jwehunt1990, May 1, 2020.
  1. Jwehunt1990
    Jwehunt1990 Bobtail Member
    May 1, 2020
    Hey guys, I’ve been perusing the forums and for some reason cannot find exactly what I’m looking for. I’m not someone that really likes to read through examples, I only want a formula to figure out exactly how to calculate my time after the 8 hours in my 8/2 split. I don’t want to know where you are or how long you drove to get there. I want a cut-and-dry formula “x-y=?” If someone can help me I would greatly appreciate it.
    nredfor88 Thanks this.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    If you take your 8hr break first you have the same amount of drive time left that you had when you stopped. then you pick up the rest of your hrs minus the ones you used after your 8hr break when you take the other two hrs.
  4. dptrucker
    dptrucker Road Train Member
    4,760
    3,319
    May 14, 2012
    adelanto,ca.
    8 hrs has to be sleeper.
    whatever left on 14 when you go on sleeper will start at end of the 8 hr break
    the 2 hr break doesn't stop the 14
  5. Big Rig Max
    Big Rig Max Light Load Member
    100
    105
    May 19, 2019
    Can do a 2/8 (reverse order) too.
    dptrucker Thanks this.
  6. Brandt
    Brandt Road Train Member
    4,674
    6,478
    Sep 17, 2012
    If I remember correctly you can't go over the 14 hour limit on any side of 8 hour sleeper time. The 8 hour sleeper time will extend/move your 14 hour clock out, but it will not stop it. It's pretty hard figure out on paper logs.
  7. Mid-May Trucker
    Mid-May Trucker Road Train Member
    1,118
    2,079
    Oct 23, 2018
    The 8 hour only works if you use up all the time before the 2 hour.
  8. Big Rig Max
    100
    105
    May 19, 2019
    HAHAHAHAHAHAHAHAHA!! So much for keeping it simple
    Look, simple 8/2
    - Drive 5 Hours
    - 8 Hour SB (Has to be SB)
    - Now have 6 Hours Drive
    - 2 Hour OFF or SB
    - Now have first 5 Hours Drive available again
    Can reverse the 8/2 as well
    Dieselboss Thanks this.
  9. not4hire
    not4hire Road Train Member
    7,142
    26,959
    May 16, 2012
    Calgary
    Split Sleeper Simplified
    • 8 hours (must be in the sleeper) pauses your 14
    • 2 hours (does not have to be in sleeper) does not pause your 14
    • the two break periods (8 and 2) can be taken in any order
    • the two work periods on either side of either break, added together, cannot exceed your 11/14/70
    • When using the split-break you enter into a cycle of
    work | rest1 | work | rest2 | work | rest1 | work | rest2 | work, etc.,
    until you return to a "normal" schedule by way of a 10-hour continuous rest or 34-hour reset.​
    Dieselboss and tscottme Thank this.
  10. bonder45
    bonder45 Road Train Member
    1,803
    5,456
    Oct 2, 2011
    Williston, ND
    Is it necessary to have 2 breaks in one work day?
    Could you wake up, run 11 hours straight drive time and then take your 10 hours off in sleeper and then go back to 11 hours right after that?
  11. Big Rig Max
    100
    105
    May 19, 2019
    There are some strategic advantages to an 8/2 in some cases. As for just every day, normal work day - Drive 11/10 Hour Break is fine.
    tscottme Thanks this.
