8/2 split scenario - help please
Discussion in 'Questions From New Drivers' started by hkchik, Aug 30, 2018.
  1. hkchik
    hkchik Bobtail Member
    29
    35
    Dec 4, 2017
    Trying to figure out the best way to get a load with two stops dropped and the next load picked up using the 8/2 split, or if he should just stick with a 10 hour reset. Feedback would be apprciated.
    Scenario 1:
    After 10 hour break was on duty/driving until 12:30p today - time left on clock 6:57 (11)/ 6:03 (4)/ 37:40
    Sleeper for 8 hours - until 8:30 pm
    On duty/drive 6 hours until 2:30 am - 0:57 / 0:03 / 31:40
    Sleeper for 4 hours until 6:30 am - 5:30 / 5:00 / 31:40
    On duty / drive 5 hours until 11:30 am - 0:30 / 0 / 26:40
    at that point another 8 or 10 hour break is required, yes?
  3. tinytim
    tinytim Road Train Member
    5,145
    19,284
    Oct 29, 2007
    Northern Ontario
    You'll be out of hours on your 14 at 10:30 am.
    The 8 hours in the berth stopped the clock. The 4 hours in the berth satisfied the rest of the split requirement but did not stop the clock and effectively moved the start of the 14 hour window to 8:30 PM
    x1Heavy and hkchik Thank this.
  4. hkchik
    29
    35
    Dec 4, 2017
    New scenario:
    4:40 am to 9:30 am on duty / drive
    9:30 am to 12:00 pm sleeper
    12:00 pm to 12:40 pm drive left on clock: 6:57 (11) / 6:03 (14) / 37:40
    12:40 pm to 8:40 pm sleeper
    8:40 pm to 2:30 am on duty / drive 5:00 / 8:00 / 31:40
    2:30 a to 6:30 a sleeper
    6:30 a to 12:30 p on duty / drive
    at that point his 14 is up and needs at least 8 hrs to reset?
  5. tinytim
    5,145
    19,284
    Oct 29, 2007
    Northern Ontario
    Same answer as above basically.
    8 hours in the berth stops the clock, anything less doesn't.
    So after the 02:30 to 06:30 (or any period of at least 2 hours off duty) the calculation of the 14 moves to a starting point where the last 8 hour or longer period in the berth ended.
    So it ended at 20:40 which means the 14 is up at 10:40.
  6. hkchik
    29
    35
    Dec 4, 2017
    Thanks. I forgot the 8 hr pauses the clock but the 2 hour doesn't. Waiting 5 hrs to load is killing the rest of the week.
    skellr and tinytim Thank this.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Once you start a 14.
    Tick tock tick tock. At some point you will stop on the 14th hour.
    It is not good to have multi stop loads, they are a parasite that munches on your ability to run miles. Stopping is to lose time and money.
    Trucking in Tennessee Thanks this.
  8. Gunner75
    Gunner75 Road Train Member
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    Just a point of contention here, but taking anything more than 2 hours to get the rest of your times back is a waste. Since the clock doesn't stop, going over 2 hours actually cuts into the drive time he's gonna be receiving.
    x1Heavy Thanks this.
  9. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    Multi stop loads are not a parasite. They usually pay better so I prefer them. The trick is figure out how to master your time.
    Im sorry I can' answer either of your scenarios. I don' understand them, tmi for me. (I doubt im alone there)
    Try asking this way. After a 10 hour break. Starting with a fresh 14.
    Drive x hours.
    Stop for x time/ (off or on duty doesn't matter.
    Drive for x hours.
    Sleeper birth for x hours
    Don' need all the times and other stuff. Just need to no drove for how long. Stopped for how long. Sleeper for how long.
    Rideandrepair Thanks this.
  10. hkchik
    29
    35
    Dec 4, 2017
    Thanks for all the help, it worked out and he'll be home yet tonight. Yay!
  11. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    Always was a subject for debate.Under old rules drivers always believed you needed a 8 hr break after splitting. I once split log for 3 weeks straight. Never heard from safety.I showed log book to another driver to prove point. I honestly don’t see any benefit to it now with the 14 hr rule. What am I missing here?Is it possible to gain 2 hrs on the 14 by taking an 8 in bunk?A simple basic example mane anyone?
