8 mpg by driving 55
Discussion in 'Ask An Owner Operator' started by Shotgun94, Oct 3, 2018.
  1. Shotgun94
    Shotgun94 Medium Load Member
    460
    317
    Sep 24, 2017
    Georgia
    Does anybody get 8 mpg? What's your setup and do you go 55? Thx
  3. Doing_flatbed_nc
    Doing_flatbed_nc Medium Load Member
    585
    846
    Mar 3, 2016
    When I removed my speed governor and started runnin 68-70, my mpg increased significantly
    Hegemeister and Shotgun94 Thank this.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Not worth it, unless you're driving somewhere that 55 is the limit, in which case I suggest you introduce your legislature to Mr Sammy Hagar and the 90s.
  5. Jenna Lane
    Jenna Lane Bobtail Member
    If you haul Flatbed no matter what you do you ll never get 8mpg we have a brand new Freightliner Cascadia the very best it has gotten is coasting downhill I got 7.6 but as soon as you shut down and idle for the night it will average 6 - 6.6.
  6. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    If all one had to do was slow down to 55 from 65 to get 8 mpg instead of 6, everyone would be doing it. The reality is the 8 mpg truck at 55 will probably still get 7 and change at 65 or 70. The same as my square box of a truck may get about 6.0-6.25 at 65 range if I slow down to 55 I might get 6.5, 6.75.
    Does it mean better mpg? Most of the time, yes. Is it such a swing in cost to really be worth it? Generally, no.
    steve092 Thanks this.
  7. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Yes,drive like theres an "eggshell" under the pedal...easy on throttle...you can still run...just slow to speed.I ve been averaging 8.2mpg running around 63mph.Get a slight run on hill,keep rpms around 1200. Another trick...find one of those gallon jugs of LUCAS and run a little every tank...keeps carbon down...helps fuel mileage..for $20 investment.JMO
  8. Shotgun94
    460
    317
    Sep 24, 2017
    Georgia
    Idling will make it drop. They burn what about a gallon per hour of idling?
  9. BUMBACLADWAR
    1,899
    1,923
    Dec 5, 2013
    Even silly stuff...like running at night with no traffic and "making the lights". The "start and stop" will wreak havoc on mileage.Even flatter alternate route (with extra highway changes will help.
    77fib77, Rideandrepair and Dave_in_AZ Thank this.
  10. Dave_in_AZ
    425,706
    Yes I can get 8. Cummins ISX 450HP / 10 SPD manual / 3.58 gears.
    Mines spec'd for 55 to 60. 55 MPH is 1250 rpm. That's the max torque with the minimum HP.
    Torque is what moves the truck.
    I typically cruise in the low 60's. I stay around 1350 rpm to 1400.
    That will get about 7.4
    But going through the communist state at 58, I'll get 8+.
    It's all about rpm's. And how hard the engine is working.
    SixShooterTransport Thanks this.
  11. Dave_in_AZ
    425,706
    Lot's of people I talk to with new 18 or 19 trucks, with autos are getting almost 9 mpg.
    8 is weak for them.
    Rideandrepair Thanks this.
