800 Marine cam
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sodapop, Apr 15, 2024.
  1. Sodapop
    Sodapop Light Load Member
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    I've got a 800 hp cam [ 332-7303 ] 70/145 titanium bulls eye turbo, 58 injectors....suggestion on right fts/fls and tune ...looking for mileage and some what power....thank you: I might have put this in wrong place...please move it if needed
  3. broke down plumber
    4,077
    32,186
    Jan 25, 2024
    Keeping it cool may be a prob , idk . But those high hp marine diesel engines use a constant supply of cool water to keep temps down
  4. shafer_joseph
    shafer_joseph Bobtail Member
    -7/60 is a decent set of numbers for the combo you have. I dont know what file you have in it at the moment though.
  5. Diesel Dave
    9,802
    33,954
    Jan 20, 2010
    Hesperia, Ca.
    There are enough files you can run without a marine cam and get similar results. The 58’s will make sure of that. I ran on my former a Cat a 5DS 601hp file with 58’s and it would pull hills like you was driving your pick up truck, this was on a 5EK series.
  6. Deere hunter
    2,186
    10,724
    Aug 5, 2017
    Shallowater Texas
    You start going down this road just make sure you have deep pockets.
  7. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    Real deep pockets
  8. Deere hunter
    2,186
    10,724
    Aug 5, 2017
    Shallowater Texas
    And if you're not an instrument rated Pilot, you better become one. if you know what I mean.
  9. mile marker 27
    mile marker 27 Road Train Member
    1,419
    1,739
    Dec 4, 2019
    At some point, with increased hp, it gets like tractor pulling and drag racing. It’s not a matter of “if” but “when”. It seems to me, that building it the first time is expensive enough but having to do it again, in a short period of time, can be a lethal blow. Only thing that might save, the average guy, is doing the wrenching himself. There’s no way with my mechanic skills I’d feel very comfortable doing this, if I only have one truck. I’m not knocking it, I’m just aware of how expensive 20-30 year old engines are, to build to 500hp, let alone 10-15 year old engines to 700-800hp.
  10. W923
    W923 Road Train Member
    1,433
    4,457
    Feb 28, 2022
    One of my customers used to have a twin turbo acert that was de acerted. I did an overhaul on it and he never could keep a clutch after that. 300k miles later he sold it…that guy put in a new clutch and it lasted about 30k miles the shop that did it had it dynoed because they couldn’t understand the clutch problem. Was making around 3200 ft lb and 830hp on the wheels. I believe it has around 500k on it now
    I guess the moral of the story is the engine could live a while with the right driver…things behind the engine might have trouble
  11. Last Call
    7,568
    45,914
    Mar 15, 2021
    Here’s my view point
    On a mechanical motor once you start trying to achieve 600 + hp it’s gets very expensive in a hurry
    On a electronic motor once you get to the 700 hp and above and you have to start throwing hard parts in it it gets costly in a hurry
    And every time you start manufacturing HP your sacrificing longevity
    Moral of the story HP does not come cheap
