'84 FLT flasher
Discussion in 'Freightliner Forum' started by Badmon, Apr 18, 2022.
  1. Badmon
    Badmon Heavy Load Member
    806
    1,503
    Oct 6, 2014
    Deep south
    This thing off my truck has no markings or anything. I'm pretty sure it's for the flashers. No one I've shown it to so far has seen one like it. A part number, or any sort of lead at all for that matter, would be greatly appreciated
  3. Badmon
    806
    1,503
    Oct 6, 2014
    Deep south
  4. AModelCat
    164,542
    Pretty much looks like a standard flasher from what I can see.
  5. Badmon
    806
    1,503
    Oct 6, 2014
    Deep south
    I haven't come across one on the internet yet with 4 prongs. Seems like everything up to date is 3 prongs. Am I missing something? Does that last female receiving end on the relay matter ?
  6. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    Try a standard heavy duty flasher, leaving the male 5OJ wire off. When my flasher went bad on my 99, the original was expensive, the Dealer gave me a standard cheaper flasher. I can’t remember if there was a Pigtail adapter involved or not. Either way it worked, and just laid in the fuse box, instead of being mounted. Looks like yours has already been adapted. Hope that helps
    Badmon Thanks this.
  7. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    I know you can get a 4 post flasher relay at NAPA..
    Rideandrepair Thanks this.
  8. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    Didn’t know FL used 4 pin flashers.
    Just use a heavy duty 3 pin. One is 12v hot. The other goes to the switch on column. The center is the pilot signal for the dash or the signal stat switch indicator light on column and is not really needed for the flasher to still work its magic.
    Rideandrepair and Last Call Thank this.
  9. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    One thing I just thought of and should have mentioned was the 3 prong flasher prong pattern is the same as an old school three prong high/low head light bulb socket. Get a good used one off of a parts car or truck or Dorman makes replacements in their “Help” line. Every old truck I encounter has had the flasher just hanging somewhere with 3 individual wires connected to it. The socket cleans it up nicely.
  10. Badmon
    806
    1,503
    Oct 6, 2014
    Deep south
    Guys, I pulled the wrong part. Found where the thing actually is and replaced it. Signals are working now. I put the wrong part back where I got it but I'm curious what the hell the thing is. No one seems to know
  11. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    Maybe at one time in it’s past life it had auxillary strobes or flashing lights mounted on it somewhere or pulled a trailer that required them? I found a 3”x3” box with 8 prongs on it in a truck once hanging under a dash by wires going to nowhere. Researched it and found it was a wrecker truck strobe flasher made by signal stat in the 1960’s. Obsolete almost 40 years. Lol!
    Badmon Thanks this.
