85 W900 Parking brake
Discussion in 'Kenworth Forum' started by Goldie85, Nov 13, 2020.
  1. Goldie85
    Goldie85 Bobtail Member
    I have a 85 W900B with a 3406 Cat. The yellow parking brake valve wont stay engaged. I can hold it in and drive the truck. Sometimes I can get it to stay in for a few minutes, but then it will leak for about 2 seconds then pop out on me, then i just hold it by hand for a while. Ill try to let off and if I dont hear it leak then it will stay but eventually leak then pop out. I had a brake chamber leaking and thought that was it, changed the chamber and nothing changed. I dont have any audible air leaks. Could it just be the valve on the dash needs to be replaced?
  3. FozzyNOK
    FozzyNOK Road Train Member
    2,482
    3,827
    Jul 18, 2007
    Oklahomistan
    You need new O rings on the spool valve.. or a new valve. ASAP.. like MORE than ASAP
    Roger McG Thanks this.
  4. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    New valve at truck pro or fleet pride or any local truck parts store
  5. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    Does this truck have 3 brake buttons 1 red 1 blue 1 yellow? if so push in the blue and yellow, try that
  6. Goldie85
    It has a third one but its not blue, its just metal. Im guessing its supposed to be blue. Ive tried putting them in together and nothing. What is the blue one used for? I dont ever use it.
  7. Roger McG
    165
    198
    Oct 22, 2016
    western mass
    If I recall Blue button was tractor only but I thought both had to be in. Is this a recent problem that has just turned up? If it is something that has just come up, as others above has stated replace the valve. A lot of todays replacement parts are no longer repairable.
  8. AModelCat
    166,444
    Yeah I believe you had to charge the system with the yellow button first, then use the blue button for the tractor and red for the trailer.
  9. AModelCat
    166,444
    If you have no obvious and serious leaks, chances are the dash valve is done.
  10. FozzyNOK
    2,482
    3,827
    Jul 18, 2007
    Oklahomistan
    Blue was an emergency system that has its own air tank/supply. It was only used to get the truck to move a VERY short distance to clear traffic etc
  11. FozzyNOK
    2,482
    3,827
    Jul 18, 2007
    Oklahomistan
