88 cat 3406 blow by
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by cptmiker, Feb 28, 2024.
  1. cptmiker
    cptmiker Bobtail Member
    Hello all new here and no too familiar with these big motors. CAT 3406 333 hp
    I have a older 1988 freightliner with 78k miles on it. It has been parked for a few years. Started right up a few days ago but I notices quite a bit of smoke coming from the Oil dip stick and the oil fill tube ran it for about 45min and no changes. I am assuming or hoping that this will settle down or go away if I drive the truck for about 50 miles or so. I find it hard to believe that the rings or the sleeve could be bad with only 74k miles on it.
  3. Magoo1968
    Magoo1968 Road Train Member
    2,181
    5,813
    Mar 18, 2021
    St Malo mb
    3000 miles a year seems legit .. If it actually is that low of mileage cylinders can be rusty or rings stuck. Not to mention seals and guides . Sitting is the worse thing for a engine. Everything dries and cracks. All you can do it run it and change oil asap after getting hot it may smoke less.
    drh72, beastr123 and Jordonh Thank this.
