89 379 heater
Discussion in 'Peterbilt Forum' started by Rabbittrucker1313, Feb 14, 2024.
  1. Rabbittrucker1313
    Rabbittrucker1313 Bobtail Member
    I cannot get my blower motor to work in my 89 379. I’ve replaced the blower motor and the reastat. And the blower motor still will not kick on. Has anyone had this problem before?
  3. Diesel Dave
    9,687
    32,971
    Jan 20, 2010
    Hesperia, Ca.
    Have you checked the fuse ?
    Oxbow and JB7 Thank this.
  4. Coolbreezin
    Coolbreezin Medium Load Member
    409
    439
    Jun 11, 2016
    Florida
    Attach + and - wires to the fan. If it works then check the fuse (see above) and the original wires.
  5. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    Diesel Dave, Last Call and Oxbow Thank this.
  6. Diesel Dave
    9,687
    32,971
    Jan 20, 2010
    Hesperia, Ca.
    I forgot to mentioned the switch. On my former 94 379, I had to place the switch because it wouldn’t work on high. When I removed the old switch, it seems it has gotten hot, had to snip the end of the wires and put new connecting ends. Have you replace the switch yet ?
  7. Last Call
    Last Call Road Train Member
    7,568
    45,913
    Mar 15, 2021
    One of the reasons switch’s and resistors give problems is because the 379 is notorious for getting moisture in the fuse box causing resistance and it likes to melt the connections at the switch and resistor
    Especially if the windshield has ever leak which a fair amount of them do
