Please help. I have a Maxitorque ES trans and I'm getting a grinding noise in low range only. Noise sounds like gears are slightly too far apart to engage. I switch to high range and those gears work fine. Also it seems to be more common if I shift into gear after coming to a stop. Had the same issue before and found the bolt on the shifter fork in trans loose. Problem as returned but the bolt is not loose. Please help
Well it could be a number of things. Input shaft bearing, cross shafts, could be gears. Could even be the springs in one of your clutch disks. Either way, i Would just pull the trans and check everything out. No big deal. You can do it
