8v92
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckingman, Oct 24, 2010.
  1. truckingman
    truckingman Guest
    Is the 8v92 the same motor as the 318?
  3. Independent
    Independent Light Load Member
    70
    17
    Oct 6, 2010
    No, the "318" is the 8v71, completely different engine.
    truckingman Thanks this.
  4. rambler
    rambler Road Train Member
    1,358
    582
    Nov 5, 2007
    The 92 series began as a 430 hp..don't know about any current ones, if there are any. They had one sorta special edition called a 00-92. It was called the "double O 92" which stood for owner operator and was rated 435hp. That was somewhere in the early or mid eighties if I remember correctly.
  5. truckingman
    truckingman Guest
    How good of a motor is the 8v92? Pros vs cons
    Does it have the ummph to pull up good size grades?
  6. 25(2)+2
    18,762
    46,051
    Sep 18, 2006
    the road less travelled
    Both Detroit 2 strokes, both V-8s, but the 92 is 21 inches displacement larger per cylinder giving it roughly 168 cubic inches more displacement.
    The 92s started at over 400 horsepower. I knew of one in a milk truck that had 475 horsepower which was pretty good for the size of the engine.
  7. 25(2)+2
    18,762
    46,051
    Sep 18, 2006
    They had oomph, but aren't the most economical engines, they also dripped oil when cooling off and warmimg up, only time they didn't drip was when warmed up and running.
  8. Independent
    70
    17
    Oct 6, 2010
    You'll go deaf driving it long term. That may or may not be a drawback, depending on your wife.
  9. MackDaddyMark
    MackDaddyMark Medium Load Member
    311
    167
    Jun 14, 2010
    Elizabeth, New Jersey
    Watch out with the 8v-92 I've worked on some buses with them and they have are a picky engine As 25+2 stated they eat up Oil like a mother and if u aren't very very on top of oil level they will seize up or throw a rod very very quickly. I'd rather an 6v-92 over an 8 less torque but the v6 wouldnt blow the hell up like the 8 is known for!
    25(2)+2 Thanks this.
  10. 25(2)+2
    18,762
    46,051
    Sep 18, 2006
    The 6v engines did seem to cause less trouble than the 8v.
    Back in the 70s, a O/O had a cabover Pete with a large sleeper, and a 12v71, engine.
    He claimed he got picked up in Nevada running 118 mph with it, and it would go up a certain hill loaded just like a normal truck would do on the level loaded. Those guys running the big enfines when asked about a hill always asked 'What hill?"
    The big Terex earthmovers ran 12v71s turbocharged with 550 horsepower, some had a 671 on the back pushing, too.
  11. truckingman
    truckingman Guest
    The truck would only be used locally so mpg isnt to big of a concern.
    So as long as I keep the oil level at the proper amount they are a pretty reliable / long lasting motor?
    So I can get a prospective how much oil would it use in a week or month?
