9 speed Eaton won't shift into low range?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 704mover, Dec 8, 2019.
  1. 704mover
    704mover Light Load Member
    Mar 8, 2018
    60
    Thanks Received:
    22
  2. 704mover
    Mar 8, 2018
    60
    Thanks Received:
    22
    Air slave is working, air plunger on the rear of the case that's behind the 4 bolt cover is working with a good o ring, i actually pulled the transmission yesterday and am gonna replace it today with another one from my parts truck. Thanks Although I may tear it apart to learn what happened first. I have nothing to lose.
  3. JGDumpTruckServices
    JGDumpTruckServices Bobtail Member
    Nov 4, 2021
    4
    Thanks Received:
  4. JGDumpTruckServices
    Nov 4, 2021
    4
    Thanks Received:
    Did you ever find out what the problem was? I’m have the same issue with my Eaton 8 speed. Does not move from 1-4, but works great 5-8. Please let me know what you found
  5. JGDumpTruckServices
    Nov 4, 2021
    4
    Thanks Received:
    Please let me know what you found with your 9 speed.
  6. Wimpie
    Wimpie Bobtail Member
    Nov 22, 2023
    Thanks Received:
    I have a problem with my 10 speed fuller.
    It splits into hi but would not split down until the truck is at a stand still.
    Valves are working fine and has good air. Could it be the friction clutch?
