9 speed hanging up
Discussion in 'Ask An Owner Operator' started by FinkPloyd, Nov 17, 2022.
  1. FinkPloyd
    FinkPloyd Light Load Member
    206
    268
    Sep 2, 2015
    International paystar 5000s 9 speed deep reduction transmission.
    Trying to upshift say from 6th to 7th itll act like there is a wall in font of the gear. Sometimes if I clutch it just a little bit itll pop in without problems. Other times itll pop in and start grinding. Rpm and road speed is the same.
    Only have this problem with the Paystars, The Macks and s series Internationals with the same transmission shift just fine.
    Reason for edit: Content
    77fib77 Thanks this.
  3. Stringb8n
    Stringb8n Road Train Member
    1,704
    2,230
    Sep 27, 2015
    Bad synchronizer in the tail of the transmission?
  4. W923
    W923 Road Train Member
    1,419
    4,389
    Feb 28, 2022
    Guessing the forks and rails are worn enough that you’re not getting the 6th fork completely back to neutral and that won’t let the 7th fork move because of how things are interlocked (on purpose)
    Try squareing the corner as you come out of sixth and over to the next gate instead of going diagonal.
    But maybe your not naming the gears the same as i am in which case what I said is meaningless.
    Bean Jr. Thanks this.
  5. FinkPloyd
    206
    268
    Sep 2, 2015
    Basically just a h pattern 8 speed, left and down is lo/lo lo then 1 through 8.
    So 6th is high range and back and 7th is to the right and up.
    W923 Thanks this.
  6. 77fib77
    77fib77 Road Train Member
    11,661
    76,926
    Jul 7, 2010
    St Louis
    Shift gate warn out? Aka the top box
  7. FinkPloyd
    206
    268
    Sep 2, 2015
    The shift tower is definatly worn, In neutral can twist the shift lever about 1/4 inch back and fourth. In gear the slop is about 3 inches side to side.
  8. W923
    1,419
    4,389
    Feb 28, 2022
    We’re on the same page then
    Try coming fully forward to the neutral position before moving over to 7th
  9. AModelCat
    164,678
    Sounds like a sticky shift rail.
