93 w900 not purging air
Discussion in 'Kenworth Forum' started by Louisg52203, Feb 27, 2025.
  1. Louisg52203
    Louisg52203 Bobtail Member
    4
    Jul 22, 2023
    Working on my father’s 93 Kenworth w900 cat 3406b and it takes forever to build air. And doesn’t purge through the air dryer. It has a new air dryer, new governor. I put a used air compressor on I know worked before it was taken off. Any idea on what it could be? I’m stumped and haven’t been able to figure this out.
  3. Big Road Skateboard
    7,491
    42,789
    May 2, 2021
    Probably the original stratoflex lines to the governor, and leaking.
    When does it quit building?
    Oxbow Thanks this.
  4. Louisg52203
    4
    Jul 22, 2023
    Normal pressure 120psi. I started it without the air dryer on too see if the lines were plugged. Pushed air like it should and nothing seemed to be in there. Push the yellow button in and it drops to 90psi. Takes forever to get to 120 unless your drive it
  5. Big Road Skateboard
    7,491
    42,789
    May 2, 2021
    You need to plumb shop air directly to the compressor outlet, and check for leaks with the truck off. If it doesn't leak, bypass the dryer.
    You've got a simple issue here. Don't expect to be able to hear a leak, trust me.
    Make sure your governor is plumbed correctly too. Supply side should be to an air tank, signal side to the dryer. When it hits pop off pressure, you should get a signal to your dryer from the governor.
    AModelCat, Oxbow and Stay Puft Thank this.
  6. Louisg52203
    4
    Jul 22, 2023
    Okay I’ll give that a shot first thing in the morning! Just wasn’t sure how to go about it. Figured something simple. Not new but not a veteran with these engines. Everything is hooked up correctly. Double, triple checked. I’ll get back to you tomorrow afternoon!
  7. Louisg52203
    4
    Jul 22, 2023
    Did what you said and found no leaks. Seemed like the air compressor wasn’t building properly. So we put a new one on it. Only purges air when driving otherwise it takes forever to build air while at idle
  8. Big Road Skateboard
    7,491
    42,789
    May 2, 2021
    Bypass the air dryer and see if it builds faster.
    Did you notice air pressure come up quickly with shop air?
    Oxbow Thanks this.
  9. Oxbow
    Oxbow Road Train Member
    13,921
    145,174
    Nov 24, 2015
    I doubt this has anything to do with your problem, especially with a new compressor, but I have had this valve (unloader?) get gummed up and stick so that it doesn't start to build again. 20190527_143327.jpg
    @Big Road Skateboard knows much more than I about this, but it only takes a second to pop it off and make sure it's not gummed up.
    Stay Puft Thanks this.
  10. abyliks
    abyliks Road Train Member
    4,227
    10,071
    May 2, 2010
    ludlow MA
    What kind of dryer is on it and does it have a. E con valve off the governor or is it just signal/purge line?
