93 W9L and trailer ABS lights
Discussion in 'Kenworth Forum' started by w9l, Mar 16, 2020.
  1. w9l
    w9l Medium Load Member
    316
    514
    Oct 12, 2013
    Have 07 and 14 trailers. Lately, when hooked to the 93 KW non abs tractor the ABS light on both trailers is likely to be on steady. Will stay on and run truck batteries down if you don't notice it and leave it for a few days. Stays on with key switch off. Doesn't do it every time. Have an 05 379 and the neither trailer gives any problem when hooked to it. Been unhooking trailer cord when I park it overnight just to be on the safe side.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK to see if the center wire in pigtail is all/ways hot with 12v even with key off, you may need to change where center wire is conn. to, and change it to a place where its got power only when key is on?
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Some had toggle switch for trailer hotline.
  5. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    In the overhead there should be a push switch. It will say trailer hot wire. If it is there and working properly you can push it to make the center wire on the cord hot. The abs light should go out. It is a combination switch and breaker.
  6. w9l
    316
    514
    Oct 12, 2013
  7. w9l
    316
    514
    Oct 12, 2013
    Yes, it has trailer hotline button in overhead. I will check and see what effect it has on center pin. Is center pin the only thing that would be hot with key off parked? When it activates light on back corner of trailer it stays lit after you shut key off. Originally, I thought it was something out of whack on the 07 trailer. The 07 has mostly been sitting for a yr or so. But when hooked to the 14 trailer that up until coronavirus mania hit was running about every day, does the same thing.
  8. bigguns
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    I believe it stays hot. Not sure really. It won’t drain your batteries.
