94 379
Discussion in 'Peterbilt Forum' started by 062, Aug 26, 2020.
  1. 062
    062 Road Train Member
    6,321
    33,958
    Oct 20, 2013
    94 379 looking for the chicken light fuse location. I could have sworn it was behind the speedometer,but I don’t see it. Last 6 is 348659. @pushbroom @Goodysnap
  3. pushbroom
    pushbroom Road Train Member
    1,788
    7,393
    Sep 1, 2012
    Fuses behind the speedo are usually engine related.
    Fuse should be in one of the 2 spare rows. Might have even fallen out.
    062 Thanks this.
  4. 062
    6,321
    33,958
    Oct 20, 2013
    Panel is all good. I remember a fuse block behind the speedometer that has 3-4 fuses but I can’t see it. This truck is far from factory wiring:confused:
  5. WREN
    WREN Medium Load Member
    378
    239
    Jul 17, 2017
    Florida panhandle
    t depends on how the wired it. You are going to have to trace the wires from the lights back until you find it. There is no specifi fuse for just those. Last one I traced on a 96 was wired into the dash lights which was retarded so I had to rewire them all.
    650cat425 and 062 Thank this.
  6. staceydude
    staceydude Road Train Member
    1,150
    5,022
    Apr 3, 2020
    There is a small group of fuses on my 94 379 on right hand side of B panel. You can see them if you pull back the C panel
    062 Thanks this.
