94 Pete 379 Speedometer not working properly
Discussion in 'Peterbilt Forum' started by AFF888, Jan 27, 2022.
  1. AFF888
    AFF888 Bobtail Member
    8
    Jan 8, 2018
    Hi, the speedometer was not working at all for months, now it reads inconsistently about 20 miles under the speed limit, sometimes nothing. The housing is cracked and looks like someone tried to patch it up with glue. Do you think this is a wiring issue or I need a new speedometer? Thank you!
  3. bad-luck
    bad-luck Road Train Member
    3,440
    6,337
    Nov 16, 2013
    Baltimore, Maryland
    Most likely the speedo is bad. If your truck had an ecm you could plug into it to see if it was the speedo or not . But with a 94 your engine is mechanical correct?
  4. AFF888
    8
    Jan 8, 2018
    yes
  5. bad-luck
    3,440
    6,337
    Nov 16, 2013
    Baltimore, Maryland
    I have a 2000 pete 379, I replaced my speedometer around 5 years ago, it was around $300. If you can fine a speedometer shop they can diagnose it for you. I know a speedometer shop, it is in Pennsylvania. Don't know where you are located.
  6. AFF888
    8
    Jan 8, 2018
    Did yours completely stop working? I'm in ND.
  7. bad-luck
    3,440
    6,337
    Nov 16, 2013
    Baltimore, Maryland
    No it worked for speed, but the miles stopped turning over
  8. bad-luck
    3,440
    6,337
    Nov 16, 2013
    Baltimore, Maryland
    Ok, here is a speedometer repair show in Lancaster Pa. You could ship it to them, not sure you want to go that route because it is cracked. Screenshot_20220128-063348_Chrome.jpg
