9400i ac/heat blend doors...help
Discussion in 'International Forum' started by Bigtruckdrivah, Oct 26, 2020.
  1. Bigtruckdrivah
    Bigtruckdrivah Light Load Member
    50
    30
    May 31, 2020
    It’s that time of year, went to switch to heat with no avail. Checked the bunk, same. Blows only cold air in both compartments.
    pulled the seat, both doors and metal arms are in order but no actuation from the either motors when I try from the dash or bunk. I don’t feel like both actuator motors would crap at the same time, will the main dash control being faulty keep the bunk control from working? The fan in the bunk works, ac button just not the hot/cold dial.
    Is there a breaker/fuse for the blend doors?
    Trucking Jobs in 30 seconds
  3. stillwurkin
    stillwurkin Road Train Member
    1,686
    2,706
    Dec 2, 2017
    On peterbilt pretty sure they work on completing the ground for a circuit connection. Yours may be the same? Check for a ground that may have corrosion? Anything else, like control panel lights not lighting up? Good luck.
    Heavyd and Bigtruckdrivah Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,067
    5,149
    Feb 4, 2009
    Like mentioned, they share the same ground eventually. The white wires are grounds. Must have a bad ground because they powered and signaled separately.
    stillwurkin Thanks this.
  5. Bigtruckdrivah
    50
    30
    May 31, 2020
    White wires at the blender door motors are ground? I’ll check!
  • Draft saved Draft deleted
