96 379 Cruise Control Gremlin
Discussion in 'Peterbilt Forum' started by GrouchoMB, Feb 8, 2012.
  1. GrouchoMB
    GrouchoMB Bobtail Member
    Surfside Beach SC
    OK, The dash light comes on but the Set/Acc/Res/Coast switch doesnt work at speed. HOWEVER, the Idle function works when parked, I can set, increase and decrease RPM. Which I guess means that both the switches and the throttle servo are working. It just wont set a speed on the road.
    Help, please?
  3. logging pete
    logging pete Bobtail Member
    14
    4
    Aug 1, 2010
    woodruff wi
    I had a bad sensor on output shaft on transmission cause that problem.
    Hanadarko Thanks this.
  4. Hanadarko
    Hanadarko Independent Owner/Operator
    2,971
    935
    Oct 1, 2009
    Midwest
    Speedo sensor would be my 1st suggestion. Some rigs have dual outputs.
    When I was troubleshooting this, I simply swapped connections at the speedo sensor output since the speedo worked.
    That wasn't it...
    This wouldn't happen to be a Detroit Engine would it?
    (asking since I don't know if 379s ever came with DD or not...)
  5. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Check the brake lite switch for the cruise if you take off the steering column panel it will be on the right side of the coloumn support looks like the brake lite switch it has an aluminum body bolted to the main dash structure with one 1/4 air line running to it if the switch goes out cruise will be in-op also if the truck is new to you you might want to hook a scan tool up to it and verify the settings could be some one set it up for the pto if it has one
  6. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    Loose yoke on the output shaft?
  7. paladin
    paladin Bobtail Member
    Cambridge MN.
    I own a 95 379. Just replaced that switch on mine. Bit of a pain. The swicch is located on the channel iron that runs across the cab bahind the dash. Looks like a standard switch except for the fact it has a 1/4" nipple.All thumbs here got it out and in with some amount of patients.Tight spot.You will need a sender socket to r&i. About 5 bucks at Napa. You might also look for the Cruise switch on the clutch linkage. It is found right under the drivers door. Another tight squeese, but did them both out on the drive.
