96 kw w900 engine fan help
Discussion in 'Kenworth Forum' started by Cjimac1115, Jul 19, 2014.
  1. Cjimac1115
    Cjimac1115 Bobtail Member
    7
    Oct 1, 2013
    Engine fan suddenly stopped working, where is fan fuse/relay ?
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    It should be located in your Fuse Box.
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Start with the fuse box-is the air line good,belt? Mine froze up last month & broke the belt. Had to replace the whole assembly.
    Can you turn the fan with your hand while the engine is off?
  5. Cjimac1115
    7
    Oct 1, 2013
    Belt and air line good - fuse good also.
  6. boneebone
    2,297
    2,372
    Mar 13, 2009
    On the front of the Engine, (if you have a Horton Fan Clutch) there should be a Switch the Airline goes into and comes out of before it goes to the Fan. Did you check that yet?
  7. turbo64
    turbo64 Light Load Member
    58
    11
    Jul 25, 2014
    That's exactly what was wrong with mine. There's a hole in the fan and another in the clutch line them up and put a 9/16 bolt in it. It will run all the time but that's better than none at all, until you can get to a shop.
