97 E7 350 in a 93 cab?
Discussion in 'Mack Forum' started by Pat Russell, Mar 12, 2016.
  1. Pat Russell
    Pat Russell Bobtail Member
    my nephew is trying to get a field truck for the farm up and running. Apparently an engine swap was done, removing the original 1993 E7 350 with a 1997 E7 350. Whoever did it just cut the harness to the fuel pump. The wires on the new engine pump don't jive with the cab wires, colors & wire numbers don't match. I know this is kind of vague but if anyone can chime in I would be most grateful.
  3. Cruisin thru
    Cruisin thru Bobtail Member
    41
    26
    Feb 20, 2016
    Utah
    Sorry man. Id google "Harness wiring color for (enter each model here)........
  4. Pat Russell
    Thanks, I was wondering if the difference in years would be compatible. I've never had much involvement with Mack trucks but from what I've read they can be quite finicky.
  5. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,065
    Nov 18, 2014
    Land of local
    From how you worded it maybe you need a new injection pump. 97 should still be the half breed mechanical. They don't pull like a cat but when a cat is going in for a rebuild the mack would be getting oiled and greased. Last of the good e7's. Didn't like the etech or ac/ai bs
    I'll ask the old man hes the mack guru
