can someone tell me where to get a diagram of my ignition switch 97 century class someone pull all the wires out of the plug having troubles
*97 freightliner ignition switch
Discussion in 'Trucks [ Eighteen Wheelers ]' started by no money, Sep 7, 2010.
do you have the last 6 of the vin?
my last 6 are 715516
any ideas why i have to use starting fluid every time i start it it starts right up?
i have uploaded the terminal location for your switch (ign) and wiring diagram for your truck (ign1). the ignition switch is in the top left corner of the diagram.
as for your starting problem does it fire right up or does it stumble for a few seconds? if it starts right up i would think your srs sensor is going bad. it is located behind the air compressor. if it stumbles for a few seconds i would look into it loosing prime.Deezl Smoke Thanks this.
