My n-14 shuts down during the heat of the day. It won'trun over 1600 rpm . Also what is engine oil temp ssuppose to run at ,mine is at 220 degrees. Any help would be appreciated.
98 9400 w/n-14
Discussion in 'International Forum' started by tktexas, Jul 5, 2014.
Are you saying it actually quits running or just stops pulling at 1600rpm? Depends how hot it is outside, and what temperature thermostats you are running, your oil temp probably isn't out of range. Stop leak and general corrosion will clog the oil cooler over time and slow down the cooling effect.
Just wont pull over 1600
Get it to Cummins so they can plug in their laptop to find the problems, should only be about $120. Then, if is something simple, you can fix it yourself.
I was told it might be the speed sensor on tranny.
The only time my N-14 shut down is when my coolant sensor went bad.
Check that -
Do you know where its located?
If you get it to Cummins, they can tell you. Then you can go buy the parts & do the repair.
On my Volvo, it is a small black plastic stick on the bottom of my coolant tank-where I fill for radiator. It;s the size of a 3 inch long pencil-black.
I was going to take it in monday. Ive hd it at two different shops and they can't tell me what's wrong with it.
