98 Freightliner Classic ABS
Discussion in 'Freightliner Forum' started by Montanaboy1988, Dec 7, 2018.
Look left of the clutch. See if theres a cover in front of the door. Some of those years. Have a panel with the test info on the back of it. MY 95 KW has it this way. Can try to get a picture of it tomorrow if you want.
Mine has the Wabco C version ABS on it.
PeteMontanaboy1988 Thanks this. -
My 99 Freightliner has the abs module under the bunk fastened to the bulkhead facing the passenger seat.
Good luck.Montanaboy1988 and Rideandrepair Thank this. -
I know it wasn’t your question but you don’t need that crapMontanaboy1988 Thanks this.
Fmcsa bulletin for required ABS
Montanaboy1988 and rank Thank this. -
This is the link fmcsa abs required vehicles.
https://www.google.com/url?sa=t&sou...Vaw3cKdK4KCAVdsXN-hol4VlR&cshid=1544504525315Montanaboy1988 Thanks this. -
The PDF I posted is old. Wasn't sure if it changed since then. I was looking for an update.
Your bulletin says it is for Canadian enforcement. Canada date of enforcement is the same in my post.Montanaboy1988 and rank Thank this.
