98 ss60 12.7 ddec4 fuel issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by istumped, Apr 3, 2023.
  1. istumped
    istumped Medium Load Member
    504
    241
    Feb 8, 2015
    What would cause engine to lose prime after sitting 24 to 36 hrs? Truck started fine ran good for a few seconds then rough and died. Tried to smash the throttle down but was too late. Fuel filter is full(davco). Doesn't happen everyday everyonce and while. This is the 3rd time it's happened. Nothing has changed except routine oil changes and fuel filter change. Is their a check valve somewhere that is acting goofy? 660k miles if it matters
    Rideandrepair Thanks this.
  3. Big Road Skateboard
    7,202
    40,925
    May 2, 2021
    Check valve in fuel return line, check valve in inlet of Davco, sucking air at some point.
    My first thought is always the return line check valve, and would assume that with full Davco housing.
    Rideandrepair and JB7 Thank this.
  4. DDguy
    DDguy Light Load Member
    157
    101
    Apr 21, 2020
    Ont. Canada
    Most likly somewhere on the Fuel Suction lines going to tank pinhole that cant be seen with the Eye
  5. Turbrospeed
    Turbrospeed Light Load Member
    144
    111
    Apr 23, 2020
    Texas
    Get a lift pump like fass/air dog and that will never happen ever again....I have one on my truck and its night n day difference.
  6. istumped
    504
    241
    Feb 8, 2015
    Can you post some photos of this setup? What exactly do you notice with that fass_ airdogg system?
  7. Turbrospeed
    144
    111
    Apr 23, 2020
    Texas
    I noticed a better delivery of power when needed, easier engine start up especially when its 32 below, smoother engine operation due to less air going to your injectors, filters can last up to 20k intervals, if your easy on the throttle and ride around 65mph you see atleast .3-.5 mpgs increase.
  8. istumped
    504
    241
    Feb 8, 2015
    Is their any way to run warm coolant thru that to keep fuel warm. I run upper midwest. Love my heated davco(while running) and overnight heater in it(plug in overnite).
  9. Turbrospeed
    144
    111
    Apr 23, 2020
    Texas
    Yeap they sell a heater kit for it also.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I had a 1998 Century with the Series 60. Mine lost its prime due to the fuel shutoff valves. Truck had long rods that you pulled to operate the valves. The weight of the rods pounded on the valve stems over the years, damaged the seal and let the air in.
  11. Turbrospeed
    144
    111
    Apr 23, 2020
    Texas
    Another good thing about having a lift pump is that it always primes the fuel system before starting the engine and adds from the top of the tanks an extra fuel return.
