99 3406e 1lw
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ak98w900, Oct 4, 2023.
  1. Ak98w900
    Ak98w900 Bobtail Member
    12
    14
    Oct 4, 2023
    Hello everyone!! I have a 99, W900, I shut off the rig; parked for a little rest. After an hour I started the truck and let it run for about 5 min and took off, then all of the sudden the yellow check engine came on and the truck started to jerk I pulled to the side and shutdown let it cool for 15 min after I checked the oil, water and belts; started the truck with no check engine light on and ran smooth for about 10 miles and started doing it again with no light on this time. I changed the fuel filters and put some injector cleaner but it didn’t fix the issue. Any suggestions where to start, please and thanks!
  3. Big Road Skateboard
    7,100
    40,319
    May 2, 2021
    Can you flash the codes?
    Oxbow Thanks this.
  4. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    read the flash codes. turn cruise off and hold the set switch up till check engine light flashes. example flash 5 times, pause and flash 5 times. that would be a code 55, which is no codes stored.
    it will keep repeating the flashes.
    Google search what codes you come up with. all 2 digit I believe
    Oxbow and Diesel Dave Thank this.
  5. Ak98w900
    12
    14
    Oct 4, 2023
    I got 55 nothing different than 55; I repeated it 3 times
    Oxbow Thanks this.
  6. Ak98w900
    12
    14
    Oct 4, 2023
  7. JB7
    JB7 Road Train Member
    1,018
    1,804
    Dec 13, 2022
    Laurel, MD
    There are times, and yours is one of those, where there will be a problem, the check engine light comes on but a code does not set. Someone needs to hook up a scan tool or laptop with software. Then review the data/parameters and look for 'counts' to see where the problem is. If the counts of a fault are not high/numerous enough a code will not set, but the problem area is identified.
    Oxbow and Crude Truckin' Thank this.
  8. Ak98w900
    12
    14
    Oct 4, 2023
    Thanks for the effort! I got it figured out while I was shaking the harness and it was rubbing against the block exposing the wires on the back side; it’s fixed now.
    Oxbow, JB7, Opendeckin and 5 others Thank this.
  9. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    It’s always nice when someone comes back and reports what the end result was! Helps others out!!
    bjytech, IH9300SBA, Stay Puft and 4 others Thank this.
