99 379 low air leaf front bushings
Discussion in 'Peterbilt Forum' started by simonsocm, May 11, 2021.
  1. simonsocm
    simonsocm Light Load Member
    111
    67
    Aug 17, 2019
    Trying to figure out the easiest way to swap these bushings myself.
    I'm thinking jack up the back end, dump the air and get to work? Aside from maybe a torch is there anything else I should be particularly worried about?
  3. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Is low air leaf different from low air? I can't keep them all straight. On my low air I don't jack up anything or dump the air. Just break out the torch, cut the bolt head or nut and let the rubber burn out. Pound everything out, clean up and reinstall.
  4. simonsocm
    111
    67
    Aug 17, 2019
    Same thing basically. I'll see if I can even get the bolts to move. Maybe just spray a whole can of pb on them. Might save me a decent amount of money.
  5. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Wouldn't bother with PB Blaster. Torch makes easy work. 30 minute job. If you could get the nut loose it's still gonna be a bugger getting bolt and old rubber out. Just turn it all to liquid with
