'99 freightliner fuel tanks
Discussion in 'Freightliner Forum' started by Pablo-UA, Apr 4, 2013.
  1. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Need advice, how to disable right fuel tank temporary? What's the easiest way.
    P/S It is '99 Shnider
  3. cdub304
    cdub304 Light Load Member
    162
    68
    Dec 7, 2009
    Rockford,IL
    first make sure your truck draws from the left tank. I would just follow the cross over tube and put a shut off on it.
  4. 25(2)+2
    18,762
    46,057
    Sep 18, 2006
    the road less travelled
    You can re plumb it if there is no shut off. Some had them, others didn't and they weren't always the same. You might be able to plug both the inlet and the outlet at the Even-flo for that tank.
    I'm not familiar with Schneider trucks from that long ago, but a 2000 Columbia had a rotary selector.
    The Even-flo got rid of the crossover on Freightliners a long time ago, another 2000 or 2001 had the levers, they had become disconnected, but could be reached from the driver's side from above the tank.
    My last Columbia had no shut off, the Cascadia has the 2 levers just about like the FLDs used to have, some of them didn't have shut-offs, either.
    Cascadia is a 2013.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    my truck takes fuel from both tanks and it is not all. If I fill one tank, fuel slowly flows to other when engine is off
  6. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    Just remove both the return line and feed line from leaking tank and cap them.do not connect them together.have done it many,many times.good luck.
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Ok, I will try)
  8. 25(2)+2
    18,762
    46,057
    Sep 18, 2006
    Actually, if the valves are open, or there are no shutoffs, they are supposed to crossover, but running the engine definitely speeds it up, Good luck with it, Pablo.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yep, it was easy. I separated RH fuel tank lines and I used fittings to use LH tank only
