99 Volvo 10 speed shifter problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lovekamp, Aug 10, 2025.
  1. Lovekamp
    Lovekamp Bobtail Member
    I'm driving a 99 Volvo with a fuller 10 speed. Once in a while usually loaded when I turn the gear shift pattern will move where I can't get it into only 7 and 8th and 9th and 10 th. I can get it into any lower gears. You can shake the gearshift around and eventually right itself. Sometimes it will do it when pulling up to a stop sign. I thought it was the isolated bushing in the linkage our mechanic says it's fine and nothing wrong with it because when I bring it in it's acting right. It's been going on for a while and was wondering if anyone has had similar problems? Ty
  3. FLHT
    FLHT Road Train Member
    1,429
    2,546
    Aug 2, 2014
    Motor mounts
    Trans mounts ?
  4. Big Road Skateboard
    7,104
    40,327
    May 2, 2021
    There's an O ring on top of the ball under the isolator. Sounds like it may be worn out.
    You have to remove the shift tower, pull the isolator pin and spring from the inside of the tower, and then you can pull the shaft out of the housing.
    When it wears out, the spring pushes the shaft up enough it'll slip out of the top plate. Screenshot_20250810_105257_Samsung Internet.jpg
    BoxCarKidd Thanks this.
  5. Big Road Skateboard
    7,104
    40,327
    May 2, 2021
    I missed the turning part. Check what @FLHT mentioned for sure
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,549
    6,641
    Aug 26, 2014
    The ball Skateboard is talking about also has a slot and a pin to keep it from turning. Could be a problem with that also.
    Big Road Skateboard Thanks this.
