99 Volvo 770 Codes and issues please help
Discussion in 'Volvo Forum' started by zack.basic, Jul 3, 2011.
  1. zack.basic
    zack.basic Bobtail Member
    Jul 3, 2011
    7
    Thanks Received:
    Lawrenceville, GA
    Hello everyone
    I just purchased a 99 Volvo 770 with a Detroit 12.7 L and a 13 spd fuller nice looking and runing truck but I just figured out how to use the #### diagnostic system and found a few codes on it I would like to know what the codes really mean and if there is a way to erase the codes so I can see if they come back up or if maybe the codes have been fixed , Please thank you
    so the codes then
    1 engine % throttle pedal voltage shorted low inactive count 1
    2 engine PID voltage shorted high inactive count 12
    3 engine SID 239 voltage shorted high inactive count 12
    4 engine SID 51 voltage shorted high inactive count 8
    5 Airbag not responding
    6 brakes ABS snsr axle 2 l data valid but low inactive count 127
    7 brakes ABS snsr axle 2 l abnormal change rate inactive count 25
    the only other issue I have is the marker lights the previous owner installed go on and off but I checked the wiring and its all there and in its not shorting out or anything the lights just go on and off randomly every 20 min and come back after 2 min don't know what that is does anybody know
  2. ohio_redneck75
    ohio_redneck75 Light Load Member
    Sep 27, 2010
    128
    Thanks Received:
    51
    coshocton,ohio
    the light issue may be the breaker is getting week.
  3. zack.basic
    Jul 3, 2011
    7
    Thanks Received:
    Lawrenceville, GA
    oh OK thank you i ll check that out
    does anybody know anything about those codes
