Let me start over my farther took his 99 Volvo into shop for the reason that opon first start the truck builds air fine once you release the tractor brakes and start driving the front tank drops to 90 psi the rear tank stays 120 only way front tank comes back up is if you bleed air down till low air buzzer light comes on than it goes back up the shop replaced air governor, air dryer another valve that came in dryer kit that went on middle airtank ,and they replaced pressure release valve its like they threw parts at it still didn't fix it my dads crust a driver I'm in military don't know to much about trucks need advise already gave away $2500 thanks
99 Volvo cummins engine automatic
Discussion in 'Volvo Forum' started by Danny boy 27, Oct 22, 2016.
Reading that made my head hurt.
Try rewriting this post using punctuation, as your question is one big Run On Sentence that's hard to understand.KB3MMX Thanks this. -
That's confusing but hopefully not so complicated as some old trucks with a 721 system and five air tanks.
The basic requirement is three air tanks. Wet tank, primary and secondary. Some times the wet tank is combined in the same tank with one of the others. There is a divider in the middle and a check valve.
The air governor has a signal line to the primary or secondary tank. The compressor will not engage intel the pressure from the signal tank is about 90 PSI. There are check valves so air cannot back flow from any tank to another. I suspect the check valve for that tank is sticking, air pressure is not equalizing, and the compressor does not come on because the signal line is connected to the other tank. Find and replace that valve.
That's what I thank but there are all kinds of different variations these days. Governors on air tanks and such. Good Luck and let us know what you find. -
Wellit does seem like something is sticking to my its 3 air tank middle tank has 2 valves one closer to dryer came with kit the other must tie off and go to the compresor
would it be dash vale or parking break valve if you don't think so please explain I'm curious thanks -
No more likely a check valve on an air tank or something similar to that. Your problem is lower air pressure in one tank than the other and they should be equal or close to it.
KISS principle: Keep it simple Sam. Used to be stupid but that's not politically correct.
Air comes in that tank from one hose that is some how connected to the other tanks. If they do not have the same pressure the gauge is wrong or there is a restriction suppling the tank.
Everything on a truck can make it seem overwhelming but keep it simple. Three hundred feet of garden hose coiled up without much water flow can be caused by a single kink. Might take a while to work through it but often pretty simple when you find it. -
I appreciate it can t believe shop can't find problem I'll look Monday let you know
could be pressure regulator valve though that adjusts the pressure that the tank supplys and adjusts the gauge pressures or try the little signal line that goes back to the compressor though i think its further down the line somewhere
I replaced pressure release valve
There is 3 airtanks the middle tank has 2 valves one I believe is regulator valve that came with dryer the other valve is also new that has 1/4 hose going to governor they said what If I ran that 1/4 hose straight to main tank or could it be unloader valve in compressor here are the valves
