a/c blower motor, a/c problems...
Discussion in 'Kenworth Forum' started by rollin coal, May 1, 2011.
  1. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,002
    Jan 9, 2012
    glasgow ky
    This is a six year old thread. Hope he has solved the problem by now! Where were you guys when he was sweating his you know what off. O well better late than never.
  3. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    T800, but I only hit inside passenger side bottom vent. Guess it could vibrate to outside housing.
  4. cjb logistics
    766
    643
    Aug 13, 2016
    Liberal Ks
    Yep but I am trending new trend on this one to see if anyone has the same issue.
  5. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    If the blower motor runs when you smack it, it's time for a new one.
  6. AModelCat
    165,353
    Ok I would check to see if you have power and ground on the motor. If it has power and ground but is stalled, motor is toast.
  7. cjb logistics
    766
    643
    Aug 13, 2016
    Liberal Ks
    Could be when I pulled it out it started, so changed ends on inlet wires and motor wires. Worked for three days, then the reach over and smack trick or good bump.
  8. Ridgeline
    22,772
    124,488
    Replace it, they wear out. If it is $120, that's better than not having it work when you need it.
  9. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    @rollin coal
    What was the problem in the end?
    How was it resolved.
  10. Nless81
    Nless81 Bobtail Member
    17
    Jul 20, 2015
    West Texas
    Check temps on the clutch relay switch and 30a ac breaker in the fuse box. Mine was getting hot and popping. Swapped the 30a breaker and the clutch stays engaged with only one pop. Old wire coupled with old blower resistor is My next though on what's making my heat. Gotta remove my cup holder and get behind the heat ducting on the 07' t600
