A/C Clutch Keeps Sticking
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mrbamcclain, Jun 7, 2014.
  1. mrbamcclain
    mrbamcclain Light Load Member
    258
    116
    May 25, 2011
    Hammond, La
    Got a York stand up on a Century N14
    Changed out the clutch last week and all worked fine. Yesterday it seized up and broke the belt. Stopped and bought a new belt and took the clutch apart to see if it would loosen.
    Put it back together and it worked fine for maybe 10 mins then burned the belt again. Now the clutch itself is moving freely but the pulley is stuck the magnet rotor.
    What would cause this? Also the white cotton dampener is it for behind the pulley or underneath it?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK. for AC. comp. being locked up? center shaft inside center of clutch, replace dryer an comp. with new not rebuilt unit for best life of AC.
  4. mrbamcclain
    258
    116
    May 25, 2011
    Hammond, La
    Yeah I found a manual online. The center shaft and key were lined up. I believe the compressor itself is locking up.
  5. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    When comp. is worn it will lock up when hot, best to replace with new comp. before it blows up an you have bits of comp. all threw the system.
  6. mrbamcclain
    258
    116
    May 25, 2011
    Hammond, La
    They just don't make stuff like they used to anymore! This comp is about 8 months old!
  7. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    May have been a rebuilt one, be sure to replace dryer at same time you change the new comp.,its just like the filter for the AC. system.
